[Request] Historical Tibber prices (NL)
Sorry for the strange request, I’m looking into my energy usage and plan to switch to dynamic rates, but I’d like to do some checking first. Can anyone share their export of Tibber (NL) hourly prices ?
I have the price as of mid-November but a whole year would be very helpful.
For some reason this information is not anywhere to be found online…
Day ahead price historical data should be available at entso-e platform
https://m-transparency.entsoe.eu/transmission-domain/r2/dayAheadPrices/show
It is, but only per day from what I could find so extracting it for a year would be a lot of work.
Also after a quick check I cannot tie the numbers together, if you look at the prices from entso the prices (as of 20:00) get lower, but for Tibber at 21.00 it’s higher than at 20.00
I have to disagree on both.
There is a possibility to download yearly prices in xml, xlsx or csv format. But you need to login to platform to get those. The sign in is for free.
And the time in entso-e platform is CET/CEST, that might explain the difference in price.
Yes, in the meantime i indeed found the same thing. problem solved.
Thank you both
-=edit=-
Found the exact prices but I’m not sure if the negative numbers I calculated are correct
Does anyone know?
2023-01-28 22_26_59-Output data - 3_11 - Math Formula
-=edit=- volgens de ANWB klopt het
