Hi all.
I want to make a push notification when a flow is started, but are struggeling to figure out how.
Any ideas or examples to share.
for example I want a push notification when this flow are started.
Thank you ![]()
And you can replace the entire left side with: If #temperature changes
How will then this flow react when one of the devices is turned on?
Yes, just realized that this your main trigger, not temperature
Any idea why I get the push notification 3 times?
one notification for every item that is turned on. Are they automatically turned on somewhere else?
What is the purpose off this flow? If one of the 5 devices on the left is turned on and the temperature is above 15 all 5 devices are turned off?
Hi, the purpose of the flow is to make sure that if the temp is below 15 and one of the heaters turns on it will get switch off again. I am a newbee so it might be a bether way to do this :-).
No, only this flow has this kind of action
That is what this flow will do.
But its all based on the temerature of one single location (prbably outside?)
Or are all heater in the same room close to the temperature meaurement…
No, it it based on the outdoor temperature
can you show a screenshot of your new flow?
oke, so you will get 1 notification, every time one of the lights has been turned on and the temp is above 15.If all are off, and you turn on one light, do you get 1 notification or more?
Yea, I gett 3 push notifications every time.
can you manually start one of the trigger on the right. do you still get three?
start one of the triggers all the way on the right (mill Kontor f.i.), by pressing right mouse and then, test from here, or when you hover over it, press the play button
