Push notification when a flow is started
Get no push messages when I start the flow from one of the device’s on the right
Do you perhaps have (enabled) copies of the flow, that could trigger the extra notifications?
No, no copies of any of my flows. That said, I always get 2 push notifications on my other flows that I have push notifications on. I have notifications on my mode flows (day, night, away)
That’s weird. If you create a new blank flow with only a start/play button and a push notification card, and send a notification to yourself, do you also get two or more notifications?
When I made a new flow with only a play button and a push notification. I only get one notification.
I think I need to do a deep dive into my flow’s, because something is wrong with them :smile:
Yes, most probably there is a flow that reacts on the turn on (or off) flow from the above units and does a different flow there
I solved the issue by making a flow for each push notification and made a trigger in the original flow to start the flow with the corresponding push notification
