One flow for monitoring several devices
Hi!
Is it possible to make one flow for monitoring several devices, and then send a push notification when one of devices reports levels above or below a fixed setpoint.
For instance one flow for monitoring all the devices with batteries, and when one of the devices reports battery below for example 20% it sends me a notification that says which device has low battery and the battery level. I have lots of Aqara temperature sensor, and I have tried the built in timeline notification in Homey. But then I get spammed with notifications telling me battery level is low, and then some minutes/hours later i reports that the same battery is Ok. So I need to build a flow that only send me a notification if the values stays low over a period of time.
I also want to build the same flow for temperature, humidity and motion (when away) from the same sensors.
I cant seem to find a then card that can bring out tags from the previous cards in the flow chain.
Is the only solution to make one flow for each sensor?
Hopefully this was understandable.
So I found the solution myself. I didnt know I needed to connect the when card with the then card to get use of the tags from the when card.
