Problem with Countdown app
May be a faulty trigger, timers are not randomly triggered :wink:
Thanks, it was a faulty flow :man_facepalming:t2: which i managed to solve.
Hi all,
having some trouble with a flow in the countdown app. i have a 3D printer witch i want to shut down when the print is ready. now i have made 3 flows:
https://homey.app/f/js6PEk
https://homey.app/f/1YBPEk
https://homey.app/f/szHPEk
what i am trying to accieve is that when de energie comes below a value the timer starts. But when is start a new print during the running time of the timer and the energie comes above a certain value the timer has to stop. When the timer is finished it need to shut down the printer and server.
Does this make any sense?
Forget these flows and get the mqtt plug-in on ur octoprint. With these messages u can do a lot more. Not guessing when printing is done but get a message when printer is done . Also the Telegram plug-in is nice to have. Get messages including a pic when printer is done .
Plz let the printer cool down before u shut it down.
And don’t forget to shut down the Pi with a http request before u pull the plug.
Ai ai that’s a lot to learn I see. Was already working on the telegram plugin now. Http request? Man is there still a lot to learn. Oke I will start from the top this weekend and work thru the option you gave me
Hi anybody such problem like me? I have motion triggered flows for lights with countown to turn off. I exeprience nonreliability in turning off my lights. Sometimes the do not turn off evethough time went to -1. Its almost like 50/50. :thinking: Running v5 stable, latest coundown app.
How many lights are you turning off from the flow, and what type (Zigbee, Z-Wave, WiFi, …) are they?
It is only one Hue bulb via hue bridge in each hall. I might be suspecting the processing limits of Homey, since I do not have PRO but big number of flows. I will also try to switch from contdown counter to “specific device inactive” cards. I also added mobile notification for flow sequence to know if both following flows go through. Manually testing all works fine.
This has most likely nothing to do with the countdown app but with the bulbs or with the flows u made.
Maybe show us the flows ur using with screenshots or shared flows so we don’t have to guess the flows are correct or not.
motion turn on light and trigger timer
Light adjustment acc. time
Timer zero turn off light
What I noticed is that it triggers the OFF flow but immediately the light turns on ( so not true that the countdown not working). I was afraid that the Turn on flow trigger could cause mess, so I also used flows sequence when i Start this flow instead of Turn on trigger is a trigger.
Maybe try this example and check if it works.
U can also delete the AND cards and check if it works but i ( personal opinion!) don’t like to start the timer on motion but i love to start the timer when motion turns off, like in the example given.
I did rebuild the flows so that the counters star when sensor goes off. Unfortunately the behavior remains. I notice when final light OFF command comes, I see it start dimming off but instantly the light turns on right away. I must have something wrong, but i checked my flows many times, i cant find how to log or debug this issue :thinking:
Past new screenies/shared flows. :wink:
Tricky stuff. It seems that the problem comes when I implement two sensors in the same room. When I disable one of the sensors, it seems working correctly. When I pass through both sensors than the light “ON trigger” repeats because sencond sensor also triggered it after the light turns OFF.
Motion turns on the light after sunset and stops the counter
Or second sensor
Dim according to daytime
I have 4 light statuses according to daytime
Start counter after sensor off
Turn off light
Then maybe use :
No matter how many sensors in a room, they will all join the flow.
Thanks, i did these:
step one
step two
etc.
EDIT: seems this is optimal. There are no double triggers, the counter stop reacts always on motion and turns on the light only when the light is off. ideal i think. Thanks for your hints
Arghh. unfortunately the problem persists even with changed flows. It means few times a day when the lights are automatically being turned off (after timer 0) they instantly turn on. Its both halls occuring I suspect the Hue lights itself. annoying :thinking:
Hi All,
Just sharing my experiences. I’m on home pro user, for past few months I have random misses on CountDown apps timer. When the timer reaches -1 but homey randomly missed, hence fail to trigger my flow. It seems like random issue, probably only once a week.
Not sure anyone have same experiences too ? :thinking:
