Please help me with my first advanced flow
Could someone help my to fix “my” advanced flow to control my lamp?
I don’t understand what I am doing wrong.
Best regards
From the flow I cant understand what you want to do.
You start and stop the timer Lustro on the same time.
The top 2 lines have the same 2 starting carts.
There is only some milliseconds delay in the “Wall Switch cart Output 1 on”.
But it could be the reason that the timer not started.
You can even make a direct line from the top Time cart to the Start timer Lustro.
Also put “Output 1 is turn on” in place of the “All” cart.
Thx for advice. I try this out later. I have identical three flows that works (light is on when motion sensor is on and it is turned on whole time motion sensor is activated - when there is no movement for 60s light is off) but I wanted to make one advanced flow, but it is obvious that I really don’t know how advanced flows are working :frowning:
I have a lot of switches and I wanted to do one advanced flow to one switch.
Here you’ll find some nice examples of flows for motion driven lights
Thx for answer
I am looking at mine and Your linked flows and there is no big difference to me.
Maybe You could write what is wrong with my advanced flow?
3 normal flows are working very good separately
I tried to make one advanced flow from 3 normal but I am missing something.
I know, but these flows work :blush:
I see “stop timer” in the top row of your flow
I don’t know the countdown app, but are you sure it should not be paused instead?
I am not sure :slight_smile:
I am only sure that 3 normal flows with countdown app with stop function are working.
I will try Your flows and give feedback
Thx a lot. This is it. I made mistake in second line - I add Motion on and not motion off.
And?
I tested it 5 minuts ago and it doesn’t work :frowning:
It turn on light. Start timer but timer doesn’t reset when there is a motion again and reaches 0 and light turn off:(
Any advice?
Do You have an idea how to merge this 3 Flows to one advanced flow? It is possible at all?
I understand that I start and stop timer at the same time but I don’t know how to fix this.
I was thinking it will work because there was a big mistake with second line. But after I check this it doesn’t :frowning:
It is not the same… I changed motion on to motion off in second line
This is waist of my time.
Why anyone can’t tell what to do?
You are not very helpfull. I am new at homey. I was using domoticz for 10 years and there was no problem at all. I can help You with Domoticz and python scripts but I really doesn’t know how advanced flows works. You can’t help me and You offend me. I was thinking homey have better community
I changed it!!!
10 post higher is my new flow with motion off in second line
Or maybe You say about something else?
Remainder? But this is the last post here.
I answered You at beginning of this conversation
“Thx for advice. I try this out later. I have identical three flows that works (light is on when motion sensor is on and it is turned on whole time motion sensor is activated - when there is no movement for 60s light is off) but I wanted to make one advanced flow, but it is obvious that I really don’t know how advanced flows are working :frowning:”
