Help to create a flow
Hello, i’m trying to do the following flow :
If the light level of my fibaro sensor is too low AND a movement is detected (by the same fibaro sensor), i want to turn on a light for 10 minutes timer before to turn off.
But i dont know how to do that in an advanced flow
Can you help me please ? :pray:
Or a mix
See https://m.youtube.com/watch?v=GdvPs9Jd8Ts&pp=ygUUaG9tZXkgYWR2YW5jZWQgZmxvd3M%3D at 5:35
Thank you guys, i will try soon
Thanks to you ! i did that, it works perfectly
You might add “Zone Inactive” card after the “Timer is finished” and if “true=turn off light, false=start Chronograph timer again”. But if it is no issue to be left in the dark, then just keep it as it is.
