Turn off lights, but delay every time motion is triggered
I can’t get my head around this…
I have a fibaro switch for the lights and also a Hue motion sensor.
I can easily turn on the fibaro/lights when motion is triggered on the motion sensor.
After 10 minutes I want them to turn off. Easy with a delay in the same flow.
But here comes the tricky part:
If I’m still in the room I want to reset the 10 minute delay / adding time so it always turns off 10 mins after the last movement registered.
If I trigger at 12:00 it will turn off at 12:10.
But if I’m in the room 12:05 it will still turn off at 12:10 and the second delay happening 12:15 is obsolete.
Result: Lights turns off while I’m in the room and I start jumping around to trigger the sensor…
I’ve tried to a global variable, but it always get overruled by the first run.
Any good ideas? The best would be if you could set a global timer and just add time to it, but I don’t see this option.
Someone made a post exactly about this “problem” years ago, and is still relevant:
I guess you have searched the forum before posting this question, so i’m not going to mention it.
Or just use “Zone activity” without any extra apps?
FLOW 1
IF zone is active
THEN turn on light
FLOW 2
IF zone is inactive for 10 minutes
THEN turn off light
Brilliant, using the Zone Activity works really nice.
I wasn’t aware about this nice feature :slight_smile:
Light turns on and if I’m still in the room the turn on period will be extended with no interruption.
I was unsure what the definition is, but it seems only to be related to the motions sensors. Testing by starting the ventilation (Fibaro based) in the same zone does not impact the “activity”.
I did try to sneak in a hand, hitting the Fibaro light switch without triggering the motion sensor - the lights will stay on as there was no motion (I don’t need that and it will never happen, just testing)
:slight_smile:
Hi there,
I do think i’ve made this feature for my toilet downstairs with using the zones,
Maybe this will give you additional info
If toilet is occupied THEN turn on light
if no movement dim light to 5%
if zone is then not active for 1minute turn off light
Zone activity is triggered by both motion sensors and door sensors.
Hi
I am having problems setting the motion sensor this way with Zone activity - it’s hit and miss if it works - I am using a Fibaro motion sensor - I have tried different settings with the Fibaro - somtimes the light wont turn on you can see the motion sensor has picked you up and see its activated the motion in the Homey app but the light sometimes doesn’t turn on - this is the same for the light going turning off - these are the flow cards and the settings of the Fibaro - any help would be great thanks
147
Hi There
I’m thinking it could an issue with the Fibaro not always connected to homey.
Since it doesn’t turn off and you don’t have any luminace I would expect the Fibaro to the issue.
With Fibaro there are two ways to connect them, default is secure, but if you add as unsecure it works perfect. At least it did for me – and I had the same experience as you.
When connection unsecure I think you have to add it and a “contact” then it will figure out that it a dimmer switch or what ever and connect it unsecurely.
If you search the forums there is an article about this.
/Lasse
Thank you for the reply
it’s been working fine for months - this has started to happen over the last couple of weeks - will give that a go to add it unsecure once I figure out how to do it - Just purchased the Aquara motion sensor - going to have a go with that over the weekend - I’m interested to see what it’s like
