One Somfy blind refuses to work
I am switching from Homewizard to Homey and everything is fine, accept for 1 of the 12 Somfy blinds.
It moves when I press the program button on the remote, it moves when I press program in the Somfy app on Homey. It moves with the remote, it moves when controlled by Homewizard, but it refuses to move with Homey.
I tried reversing the signal, I tried moving the Homey, I tried changing the length of the signal, but all in vain.
Right now I am out of options, except for controlling the blind with Homey through Homewizard, which, of course, can not be the solution.
I have exactly the same. Is there a soluciĂłn? I have changed my router. After that it happens. Therefor it works nice.
If you use a flow to control the blinds, did you try to send the signals with an interval of two or three seconds? Here that solved the issue, it is a known problem.
Yes, I already ran into that one too. But I already solved that. But that didn’t help for that 1 blind.
I already tried multiple commands and I also moved the Homey even closer to the blind. Because from the 12 blinds, the problem blind is the second closest to the Homey. The blinds in my bedroom are much further away, divide by two ceilings and some walls. The garden door (the problem blind) only has 1 wall. Weird? It sure is.
Also thought about interference with other signals, but when I hold the Somfy remote over the Homey (same line of sight) it works with the remote.
In the Athom archive (I’m new to Homey) I found a similar issue. Unfortunately there wasn’t a solution provided.
Do I understand it correctly that it does work with the Homey, but not when activating it through a flow?
No, the specific blind doesn’t work at all with Homey. Not through a flow and not when I use the app. The Somfy remote itself (hardware) works. The Homewizard works as well. Now I am sending a scene command to my Homewizard to open or close the blind. That works fine, but is not quite what I had in mind when I bought the Homey :slight_smile:
I even tried to make a new device in Homey with a combined group from blinds. After that I could give 1 command and all blinds were moving. Except… sure, the garden door.
Yes, I’m afraid that will be the last option. Problem is: which developer?
If it is the app… why do all the other blinds work?
If it is the Homey… why do all the other blinds work?
If it is the RTS engine… why do the remote and Homewizard work?
If it is interference… well, then it should work at least sometimes (and fail on the remote, Homewizard too)
Is it included correctly? Did you try to remove it and then to add it again? That would be my last option …
About three times I guess. And also on a combined channel. Thanks for thinking with me, it looks I really tried everything. Go ask Athom support I guess.
That’s right. I’ll try that. Keep you all posted.
I have been busy for more then a few hours now. but the screen is not working.
@sbstrop: which router you use. I use the Tplink archer c7 v4.
Linksys, but I don’t think the router has something to do with it. The signals are not Wifi, but 433 MHz. And yes, there could be some interference, but that would also be the case for the Homewizard or the Somfy remote. But, I could try tomorrow with the Wifi shut down. Keep you posted.
You cannot shut the wifi down because the signal goes from your tablet to the router, then to the server of Homey somewhere in the cloud, then to the router and then to the Homey and at least to the somfy. I think.
Correct, when I would use my tablet. But I can use any sensor to start a flow which will try to close the blind. And I have an Aeotec Wallmote. So that could work. But yes, it will take some time.
Ik ga even verder op zijn Nederlands. Is toch wat gemakkelijker. De router wordt gebruikt als accespoint. De oude router werd ook zo gebruikt. Nu ga ik de oude router weer installeren. Maar dat duurt nog even. Deze week komen ze het glasvezelnet aansluiten. Daar wacht ik op.
If you could please keep the conversation in English as much as possible, then more people will be able to participate and help you. If you would rather not or can’t communicate in English then please check out Non-English boards at
https://community.homey.app/c/non-english
Nederlands (Dutch), Dansk (Danish), Deutsch (German), Svenska (Swedish) , Français (French), Polskie (Polish), Fiński (Finnish)
OK I will do that. I have also a ICS-2000 from KAKU. I used it before the Homey. I just tried it again. And the blind is working. So it has to be the Homey which is not working correctly.
Support is going through the diagnostic file for me, so I’ll wait what they find out.
Suddenly I thought just connect the good somfy remote to the “bad” motor. And then the give the Homey a command for the good remote. Not working. I couldn’t connect the bad to the good one. But I could connect the bad to the good.!!! So I think the the remote or the somfy motor is not working correct. But the Homey is working correctly. This afternoon I going to try a SCX-2000.
