Nouvelle application smart life
Is this the right place to submit a request for the creation of a new application? If so, I would like someone to develop an application that manages this equipment https://fr.aliexpress.com/item/1005005606019896.html?spm=a2g0o.order_list.order_list_main.28.68d65e5bF77il5&gatewayAdapt=glo2fra. This application, called Smart Life, is available on the Apple App Store https://apps.apple.com/fr/app/smart-life-smart-living/id1115101477 and also allows for the management of air conditioners. I am aware of Tuya (https://community.homey.app/t/app-pro-tuyapi-neo-coolcam-wall-plug-wifi-app/15811/322), but I find the setup process to obtain an API key very complicated. Is my request possible?
So instead of asking help with that app, you’re asking for a new app?
The complicated process is not the fault of the Homey app but the fault of how TuYa’s systems work, so a new app will not miraculously make the process less complicated.
Smartlife is just a lable of tuya…
And there are already many topics and multiple apps for Search results for 'Tuya order:latest' - Homey Community Forum
Maybe ask Tuya
or switch to a supported brand .
Thank you, I submitted a request through your link. Do you know another brand that can manage this equipment so that I can download another Homey application?
Yes, what I’m looking for is a new application that is based on the Smart Life app and can retrieve account information to control RGB LED strips and an air conditioner.
That app already exists, and it’s called the TuYa Cloud app.
Yes, I tried it, but I couldn’t get the LED strip to be discovered. Do you think it would be possible with this application and this strip? Perhaps it’s because it’s already associated with the Smart Life app and needs to be dissociated before linking it with Tuya Cloud?
It’s probably possible with that app, yes, you just need to follow all instructions very carefully. Smart Life and TuYa are the same.
Ok, thank you. I will analyze and try to install it with this application.
After analyzing, this application is as complicated as the other one, as it also requires the creation of the API access token. It’s this part that I want to ignore. It would have been simpler if the API access token were available directly in the Smart Life application, as is the case with some other apps. I tried to create the key API access token through the procedure, but it didn’t work. Too bad, I thought it would be easier. I made a purchase for nothing.
But nothing the community can do,
No need to complain here,
Or to put in another way: you bought a cheap device and are not willing to live with the consequences :man_shrugging:t3:
Very unpleasant contempt…
we don’t buy Tuya devices because they are cheap but also because often there are no other availability for the features they offer.
Not everybody is a millionaire either…
Please respect people and their choice. They just would like Homey to support their device (or homey will fail )
Christopher Charpentier
This has nothing to do with any of that. There’s a reason why TuYa devices are cheap: it’s much easier for manufacturers to put a ready-made TuYa chip in their devices instead of having to set up their own infrastructure, and in my experience especially the really cheap devices are of questionable quality (and if we venture into conspiracy theory territory, you could wonder who would benefit from having all those millions devices being connected to cloud servers controlled by a Chinese entity).
I don’t mind people buying TuYa devices at all, I have some myself. But TuYa doesn’t really want other home automation systems to be able to control their devices (why not? who knows, perhaps they just want to be able to collect all your personal data themselves…) and they make it very difficult to do so if you want to persevere. That’s not the fault of Homey, or Home Assistant (which has to deal with the very same situation).
If you want to use TuYa devices with “alternative” systems like Homey, you have to put up with the roadblocks that TuYa puts up before you can do so. It’s not Homey making the process difficult, it’s TuYa themselves. Complaining about it here is useless as nobody can do anything about it.
Not for nothing, dudu, cheer up.
Few users notice the following sections in the 1st post of the Tuya Cloud topic, which states you can use almost any Tuya (based) device with Homey, but not directly as Tuya Cloud app supported device:
When you have any questions , please use the Tuya Cloud topic.
And read / use search function: almost any issue + solutions are available
bonjour la team
merci pour vos vidéos. J’ai une grande question. Dans ma maison, j’ai installé 56 interrupteurs connectés Tuya/Smart Life, au total 182 boutons, deux cordons de LED RGB 30 mètres plafond corniche , ainsi que deux portes de garage et 7 caméras Blink, avec une Echo Show 10 3e génération au milieu de ma cuisine/salon pour utiliser Alexa. Jais aussi le pilotage des lampes de la piscine vigipool et ca marche avec smartlife & tuya et alexa … Ma question est : comment faire ? Exemple : 6 interrupteurs dans la chambre 1, 12 boutons au total. Comment créer un scénario où, en appuyant sur le bouton adresse 0101 “lumière plafond chambre 1”, je commande en même temps les boutons 0101-0203-0301 qui allument la lumière du plafond, sachant que seul le bouton 0301, nommé CH1 pour Alexa, commande la lumière du plafond raccordement électrique ? Les autres sont connectés au neutre et reconnus par Alexa et Smart Life. Je n’arrive pas à piloter le groupe des trois boutons en appuyant sur 0203 ou 0101 pour commander le 0301, qui lui et raccordé à la lampe du plafond. Si vous avez la solution, car j’ai une bonne trentaine de scénarios à créer. J’ai aussi acheté Homey Pro avec l’adaptateur Ethernet et Homey Bridge pour une meilleure couverture et stabilité… et la par-contre impossible de reconnaitre smartlife ??? help help impossible de connecter sur homey pro
Qui fera l’objet d’une évolution de l’installation futur avec un dashboard
Merci pour votre aide…
Wilfrid de Cannes
@wilfrid pls edit and translate your post
If you could please keep the conversation in English as much as possible, then more people will be able to participate and help you. Please translate your post into English, otherwise it will be deleted in three days to keep the thread in just one language as stated in the forum rules Welcome to the forum!
Please do also check out the categories in other languages:
Dansk (Danish)
Deutsch (German)
Español (Spanish)
Français (French)
Italiano (Italian)
Nederlands (Dutch)
Norsk (Norwegian)
Polskie (Polish)
Suomeksi (Finnish)
Svenska (Swedish)
If you need help, because depending on the trust level of your account, you may have limited permissions, please PM me or another moderator or reply to this post.
bonjour la team
Wilfrid de Cannes
homey pro et smartlife ne marche pas merci pour reponse ca plus 1 mois que je suis dessus
(Attachment facture.pdf is missing)
Bonjour,
Vous avez besoin de l’application communautaire Tuya Cloud, commencez ici :
Bonjour merci de répondre juste ça vous oubliez de le dire sur vos vidéos tu coup ce n’est pas correct oui c’est simple comme facile et au top non ces faux un mensonge… de votre part si j’avais su je n’aurais pas acheté Homey Pro plus le Bridge et Ethernet… car pas du tout la vérité vos publicités…
