Nedis WiFi Smart plug and Nedis® SmartLife
Thank you!
The issue seems to be here:
NOT supported devices and functions
  • All devices not listed above
  • Energie values and devices
  • Kitchen devices
  • Color for some lights
  • Sensors
Weird thou that the device appeared in homey once it was paired with tuya app. Not showing at all when paired with smartlife app.
Heb van 4 Nedis Smartlife ledlampen IDs, Keys gevonden via de Tuya site en ip adressen in mijn AP overzicht (laatste tekens ID komt overeen met Mac adres)
Ook alles correct kunnen invullen in de app. Device wordt ook geaccepteerd en is online, maar kan niet worden bediend.
In de Smartlife app werkt het correct.
Iemand een oplossing?
De andere Tuya app
Just to make sure… the conclusion is, that nedis power plug with metering does not work with Homey, or am I wrong?
@Hjelmdal
Tuya Cloud app got major updates and supports more device types.
Smart plugs with power measuring are supported now.
If something’s not working, better ask in the official Tuya Cloud topic
Where can we see a list of all devices (sockets) supported with power measurement?
Looking for this plug:
Nedis Smartlife WIFIP121FWT / 1906056
AFAIK there’s no list.
In theory all Tuya wifi compatible measuring plugs should work.
And, if not, you can still use it using the “Raw commands” option.
Can you please explain? I can’t even connect the Nedis app to the Tuya cloud… Getting an error while scanning the QR-code that I should use ‘the original app’.
Move everything you have from the Nedis app to the SmartLife app instead and then connect it with the Tuya Cloud homey-app. Takes a bit of time but works perfectly for me.
