Tob
December 29, 2022, 7:16am
1
Hi
I have a simple need for a outdoor wall plug that works with homey pro
Tried searching the forum but i cant find a simple/good solution.
Right now im running a couple of nedis/tuya outdoor wifi powerplugs, cheap, reports power consumption (to nedis “SmartLife” cloud) and are stable/works well:
https://nedis.com/en-us/product/security-safety/smart-home/power/550710067/smartlife-smart-plug-wi-fi-ip44-power-meter-3680-w-plug-with-earth-contact-type-f-cee-77-30-40-0c-android-ios-grey-white
But they do not integrate with Homey. There is some ESPHome/Tasmota flash trickery possible that supposedley would make them work with HA (and homey)
But i would prefer to buy new powerplugs that works out of the box instead
Req
Reporting Power consumption to homey
On/off capable (doh!)
Ip44 spec or better (weather proof)
EU socket
Pref
Zigbee or WiFi
Connect directly to Homey
10-30 euro range
Not cloud based
Flashing hardware or building my own case (not enough time)
Some considered alternatives and related posts and questions
After some research, my power plugs seems to work nedis cloud now (will test) but would prefera a non cloud based solution…
@Hjelmdal
Tuya Cloud app got major updates and supports more device types.
Smart plugs with power measuring are supported now.
If something’s not working, better ask in the official Tuya Cloud topic
Hoping someone have a nice solution to this simple problem
Take care!
//T
Tob
December 29, 2022, 10:32am
2
Went the tuya cloud route for now
Took some effort to setup but now i got power consumption working with the new developer api integration.
Here is some threads to follow if someone else want to try this:
Homey app:
Tuya Cloud app
NOTE: This app is no longer actively maintained, only PR (Pull Requests) will be merged and published as update;
The developer does not respond to questions / requests any longer.
App store:
Test version (with more supported devices):
Homey App for the Tuya cloud
The word API will be used often. So, what is that about?
API = special developed connection between Homey and Tuya servers
The official API is now supported.
It requires an extra development account and keys.
Th…
Tuya cloud setup steps:
“Data center issues”
“QR code expired problem”
Use the correct app, only got it to work with the “Tuya” app and not the “Nedis” app
opened 08:14AM - 09 Dec 21 UTC
closed 09:36AM - 08 Apr 22 UTC
bug
no-issue-activity
**Describe the bug**
No success in adding my devices. Linking Tuya App account … is not working for me.
When I scan the QR I always get QR code has expired.
I'm in the correct data center: Central Europe Data Center
**Expected behavior**
My Tuya app account is linked and I can add my devices.
DirkG
December 29, 2022, 12:39pm
3
Even if you have already decided to use Tuya, it’s funny to me that you refer to posts from 2018 and 2019. In the meantime, many things have changed.
Genereic device? No → app available
No power consumption? No → have a look at the app in the app store
Zwave → Yes
Expensive → Depends on the POV
Tob
December 29, 2022, 7:41pm
4
Thank you @DirkG
I’m glad that I could bring a smile to your face. It’s always nice to be able to brighten someone’s day and bring a little bit of joy and happiness into their life.
Do you have experience running the Pop outdoor socket? Is the “new” app integration working well? And do you have any advice / experience with other outdoor power plugs?
DirkG
December 30, 2022, 12:31pm
5
No, I don’t have no experience with the POPP Outdoor Plug. In the forum it is reported that some have problems, others have no problems. I could imagine that the problems might be related to an old firmware.
I also have no experience with other outdoor plugs. But in the outdoor area I have 4 sockets in use. For this I have put 1 Fibaro Double Switch 2 module in an IP55 junction box. From the junction box I have installed 2 cables to the outdoor sockets.
