Manual adjusting temperature in the "Climate"-menu and directly in the different apps
I am trying to manually adjust temperature for different thermostats (Futurehome and Sensibo heat pump) using the manual “scrolling wheels” in the Climate-menu and also directly in the apps (Futurehome and Sensibo). I manage to adjust the temperature as i want to, but after a little while (15 minutes?) are the temperatures reset back to the original values. The same happens for all the Futurehome thermostats and Sensibo heat pump.
I am looking for some kind of “Save”-button to save my changes, but i cant find any.
Is it so that manual adjusting of temperature is not possible in Homey? Or what am i doing wrong??
Do you adjust the Target-temperature or the Measured-temperature?
It is the wanted temperature…as shown in the attached example (in Norwegian).
So… i try to change the “25” using the “wheel”. It works fine, but after a few minutes, it has returned to 25 again… Very strange ?!?
It probably jumps back to the predefined temperature of the thermostat’s own program? Like:
Homey: “hey set target temp to 28”
Thermostat: “well…. NO”
Thermostat sets target temp to previous / program temperature.
Yes, this is correct. It is the temperature defined locally, either on the heat pump or the Futurehome thermostat. But, what is the use of Homey-Climate functions then?? If i nevertheless have to use the local setting to define the temperature….??
I don’t know the app. For example the tadoZones app for tado thermostats has all kinds of cards, to control the temperature and when to go back to the schedule (or not)
Take a look at the app’s flow cards here:
I guess you’ll have to contact the Sensibo & Futurehome app devs:
mailto:homey-futurehome@drenso.nl
(this info can be found at the app pages @ homey.app store)
Thanks! Yes, i have to contact especially Futurehome, because i have a lot of those thermostats and they all behave in the same (strange?) way. Maybe others with Futurehome-products know more about this?
Update: I figured out that the Futurehome thermostats were in local “regulator” mode. Somehow this affects adjusting wanted temperature, even though they are not responding to the given temperature. So, changing mode to “thermostat” instead of “regulator” did the trick :slight_smile: !
And the Sensibo heat pump manager was corrected by a factory reset of both heat pump and Sensibo.
