OH2TH
March 23, 2021, 6:03pm
1
Contribute
If you enjoy what I do, consider supporting me on Ko-fi or Paypal ! Every little bit means the world!
Introduction
Sensibo Sky, Sensibo Air, Sensibo Pure and Sensibo Room Sensors
Installation
Get an API-key from https://home.sensibo.com/me/api . On the form, enter an API key name and press the add api key
button.
Set the API-key during pairing of the device
Device Features
Click the to view details.
Device: Sensibo
Models
Sensibo Sky
Sensibo Air
Sensibo Air Pro
Capabilities
All devices
On / off
Fan level
Fan mode
Target temperature
Swing
Horizontal swing
Climate React
Temperature
Humidity
Last seen
Filter clean due date
Filter clean due hours
Filter run hours
Air Pro devices
CO2
TVOC
Inside Air Quality Score
Flow cards: When - Triggers
Thermostat mode changed
The temperature changed
The humidity changed
Device turned on
Device turned off
Device offline
Timer created
Timer fired
Timer deleted
AC state changed
Climate React changed
Filter alarm changed
Flow cards: And - Conditions
Thermostat mode is
Is on
Climate React is enabled / disabled
Timer is enabled / disabled
Flow cards: Then - Actions
Set the temperature
Set the mode (Automatic, Heat, Cool, Off)
Turn on
Turn off
Set the fan mode
Set the fan level
Set Swing mode
Set Horizontal swing mode
Control Climate React
Control Pure Boost
Control light
Sync power state
Set timer
Delete timer
Device: Sensibo Pure
Capabilities
On / off
Fan level
Temperature
Humidity
Last seen
Filter run hours
Device turned on
Device turned off
Air quality changed
Device offline
Timer created
Timer fired
Timer deleted
Is on
Turn on
Turn off
Set the fan level
Control Pure Boost
Control light
Set timer
Delete timer
Device: Sensibo Room Sensor
Capabilities
Temperature
Humidity
Battery
Last seen
The battery level changed
Device offline
Device: Sensibo Elements
Capabilities
Temperature
Humidity
CO2
PM2.5
TVOC
Ethanol
Last seen
The CO2 changed
The PM2.5 changed
The TVOC changed
The Ethanol changed
The Inside Air Quality Score changed
Device offline changed
Useful links
OH2TH
September 26, 2023, 2:41pm
6
FAQ - Frequently asked questions
No devices found with a new API-key
If you have just created the API-key, the Sensibo API might return an empty list. Try again after a few minutes.
OH2TH
September 26, 2023, 2:42pm
7
TODO - Features Requested
If you would like to request a feature to this app, please open a feature request at Github .
Tb1
May 11, 2020, 4:51am
9
Why isn’t it possible to set fan mode? I can tell Google assistant to set cool, heat and auto but not fan.
balmli
May 11, 2020, 5:48am
10
Yes, I guess that’s not possible in the current version of the app.
It’s possible to set the fan mode with a flow.
Tb1
May 12, 2020, 3:58am
11
Yes I am aware of that but it had been nice to do this on the thermostat
Caseda
May 12, 2020, 5:29am
12
Google home only supports the 3 modes: cool, heat and auto, any other modes are not supported, nothing we can do about that as it is a Google home limitation (Amazon Echo and Homekit have this same limitation)
Rwin
May 18, 2020, 7:32am
13
Great app, one of the most usefull i came across. Sensibo and Homey combination makes it completely endless as for possibility’s.
Had mine working within minutes. I’ve got an Haier Airco that can be controlled by an app using a USB Wifi interface. This worked for 3 years but it’s an crappy app and they didn’t want to share the API etc for me to build an app. I removed the wireless interface and used the USB port to power the Sensibo. Routed the USB cable within the airco and the Sensibo on the side.
One question though… My Haier only supports vertical swing, not horizontal. There is no way i can control this direction with your app. Any idea why? Ik errors with code 450, probably because horizontal swing is not in use with this airco.
balmli
May 19, 2020, 7:12am
14
Thanks.
Can you control the swing from the Sensibo app?
Rwin
May 20, 2020, 9:46am
15
Yes, tried it and vertical swing works. Upper position, down position, stop and swing continuously.
balmli
May 22, 2020, 6:31am
16
This is the current list of swing modes that are supported:
Fixed bottom
Fixed middle bottom
Fixed middle top
Fixed middle
Fixed top
Range bottom
Range full
Range middle
Range top
Stopped
Rwin
May 22, 2020, 12:57pm
17
I know… but the way the app/contols are build it is selecting every mode that comes by. Mine only looks to have fixed top, range full and stop. It errors as soon as an other one had passed
balmli
May 22, 2020, 3:05pm
18
But you can set the swing with a flow ?
Rwin
May 22, 2020, 4:37pm
19
Yes i can, but the controls from your app are very nice. Can’t you use another control way for the swing? Not all aircos have all functions
balmli
May 24, 2020, 1:30pm
20
I will create a fix for this:
support “Horizontal” and “Both” swing modes
check that the selected swing mode is among the supported swing modes for the device
balmli
May 24, 2020, 1:42pm
21
Here is v. 1.2.1 ready for testing.
balmli
June 6, 2020, 5:43am
22
V. 1.3.0 with support for Climate React is now ready for testing:
Rrrr
June 6, 2020, 1:38pm
23
Amazing work! Thank you for your contribution. Climate React is a killer feature for Sensibo and now we can schedule CR which is what the sensibo app cannot do.
