LG WebOS app for Homey Pro 2023
Sorry for my bad explanation. Of course I have the card that says “the time is later than”.
I don´t know to make the flow more simple than:
"WHEN "LG tv stopped playing (also tried inactive) “AND” the time is later than xxxx “THEN” turn off the lights.
As mentioned the flow (advanced) works with the “play flow” in the webinterface but in real life it doesn´t work. So I do not understand what the sending of a notification should change? I have several flows that includes my HUE lights without any problem so I don´t think that sending me a notification should make any diffence - Homey talks to my HUE lights without any problem.
I think that the lights doesn´t turn off is a valid confirmation just as a notification.
Your suggestions is most appriceated and my experience is that this forum helps out. Sometimes I get stuck in a wrong mindset - so thank You.
There are three things that can go wrong with that flow:
  • the WHEN card doesn’t work
  • the AND card doesn’t work
  • the THEN card doesn’t work
So you need to find out which one isn’t working. My guess would be the WHEN card, which is why I proposed to use a simple flow that only has two cards.
Thanks robertklep I will try it. However if the when card is the problem it looks like a catch22?
I Will try the solution and try when, and in my case then
ons 27 nov. 2024 kl. 19:21 skrev Robert Klep via Homey Community Forum <notifications@athom.discoursemail.com>:
In that case you know you should contact the app developer for the LG WebOS app.
I will try, robertklep You´re help is much appreciated.
I’ve been encountering the issue lately that when my LG TV is turned on, it doesn’t show up as “on” in Homey. It still appears as “off” there and, therefore, cannot be controlled. If I manually restart the LG WebOS app in Homey, it works again. A possibly useful note: the LG ThinQ app on my phone does show the correct status.
Some more testing done, I now have a simple flow WHEN lgtv is turned off (also tried inactive) turn off a specific light. Still doesn´t work in real life but in the app when trying the flow.
So turning off the TV in the Homey app it works turning off the light but the problem that I have an AppleTv connected so when I turn off the LG tv in the homey app the flow works but it doesn´t infact turn the TV off due to the fact that the AppleTV isn´t turned off.
Hope You understand, I think maybe that the problem is the Apple TV that is turned off - sends a signal via HDMI to also turn off the LG TV (that is done in real life) but somehow the LG TV app in Homey doesn´t recognize this.
Any suggestions
Still sounds like you should contact the app developer.
Hi.
I have a Homey Pro 2023. I have a lot of different home products connected via app’s to it. I recently got a LG OLED TV and I downloaded LG WebOS app to control the TV but I doesnt’ appear in a flow when building logics with either ‘When, And or Then’.
I have installed the LG WebOS app and I can see it in the Settings/Apps but it does not appear as an option when creating flows.
I have restarted the app, rebooted my Homey.
What could be wrong? Any tips?
“Install a new device, select LG WebOS and connect your TV”
Few apps work without installing a device first.
Of course. Just totally slipped my mind. Haven’t added any device for a long time :wink:
Thanx
Has anyone installed this recently ? I just had a go and it failed poorly :frowning:
I did an npm install followed by an npm audit fix in the unzipped dir. Still lots of issues, but was able to do homey app install
Now if I can just get it to open a browser/webapp with a given url …
This almost works - I see the popup, but never get the video stream
Using the methodology from here
I have agentdvr in a docker container, the camera is added and I can see the doorbell camera feed in agentdvr just fine.
