LG SIGNATURE OLED TV W9 / Homey
Hello
Is there any way to control this Tv from Homey, I can’t find anything
apple Home kit seems to work but nothing on homey that I can find
PS: New to this
I presume you know that you have to install an app for every brand of device you want to control via homey.
Having that said, you can try installing the webos app from athom
or
install webos plus from @MaxvandeLaar which works a lot better, but has to be installed via CLI.
Search this forum for “webos better” or “CLI“ to find the answers needed to do the second option.
Yes I know :wink:
I looked at the webos app from athom and that is for webOS 2 & webOS 3
my tv has 4.xx something and it doesn’t work.
i will check webos plus from @MaxvandeLaar, thanks for the tip.
@aiidDaH,
If you need any help, just let me know; always happy to help.
I have only tv’s with webos 3.x so I am very curious if it works for you. I haven’t received any feedback it wasn’t working for someone yet.
@MaxvandeLaar
just tried and I get this this errors, app found both of my LG tvs
@aiidDaH thanks for trying it out. Not a huge issue. Check this issue https://github.com/MaxvandeLaar/homey-webos-plus/issues/4
fixed, works like charm
many thx to you @MaxvandeLaar
Good to hear. Keep track of the other forum topic to get notifications on updates.
Is this app still available and if so how do you install it and is it the source files for 3.1.2 or something else?
I am new to Homey and whilst I have downloaded and installed node.js / nvm it is really unclear how to then use it, it doesn’t seem to create an application?
You need to download the source code for the app. In the app directory (the directory which contains the package.json and app.js), click on the address bar in file explorer and type cmd You should then run npm install. You can then run homey app install afterwards.
Is this for a windows device and if so do you know how to do on a Mac?
I use a Windows PC, but the commands should work for Mac OS as well (AFAIK the commands are the same since Node is cross-platform)
