Keep getting error after reboot
Hi, Just got my Homey. I am very happy with it but i have a small problem.
After reboots i keep getting these errors. “Retreiving fenceArray failed: Fejl: ENOENT: no such file or directory, open '/userdata/owntracks_fences.json” and it seems that my locatation is not registred.
I cannot find any arthicles that have a solution.
The only one is this one without a solution " Foutmelding op de tijdlijn - :netherlands: Nederlands (Dutch) / Vragen & hulp - Homey Community Forum"
Do you have any solutions ?
Configure the Owntracks app: Location and Presence App for Homey | Homey
Correct.
I think it can be ignored if you don’t have “Location & Presence” installed.
Question: why do you reboot Homey?
Hi, Thanks for the reply.
Is there a way to remove the messages, just for my OCD ;o)
The reason for the reboot is that i also have problems with my Philips HUE app. It shows all units as offline several times a day.
I cannot figure out if it is Homey or my Phillips Hue bridge. They are online in the native HUE app.
A reboot doesn’t help so i will stop the reboots.
Swipe the message to the left and hit the X
Or install < Timeline Manager² >
(Info: click )
Then this flow takes care of it:
If…
Homey has started
Then…
TimelineManager - Remove messages containing “Owntracks” with a delay of 5m
I think it could be wifi related. Try some tips mentioned here:
Hej Lars.
Fik du løst dit problem med HUE. Mine broer er gået offline på Homey, og jeg kan ikke få dem ind igen.
If you could please keep the conversation in English as much as possible, then more people will be able to participate and help you. If you would rather not or can’t communicate in English then please check out Non-English boards/categories:
Dansk (Danish)
