Is there no card , for the shelly Plug Pro & Shelly 1/ 2 Pro
Hi , is there no card , for the shelly Plug Pro & Shelly 1/ 2 Pro
  • If : the consumption IS lesser / Bigger than … W
    I found the card IF : the consumption IS Going lesser / Bigger than … W
Are you looking for a Trigger or a Condition ?
A Trigger
Is not a trigger but a condition
ok but I need this condition as trigger
same issue with the Selly Plus HT, I could used as trigger : Temp will going too less than …
But I need the triggen : Temp IS lesser than …
Thats not possible, a condition exists and a trigger happens…
What you ask is a trigger on something that is true but doesn’t change.
yes it is changing
Is there a trigger The Temp changed? Create flow with a condition it is less…
Geurt , Nederlands ?
VB #Als # de themp lagers is dan … # EN # het is 10.00 Hrs # EN # de deur gaat open # dan # schakel de verwarming Aan
ok
example :#If # the themp is lower than … # EN # it is 10.00 Hrs # EN # the door opens # then # switch the heating On
That’s not how flows work.
“IF the temperature changed AND the temperature is less than X°C”
Also, “it is 10.00Hrs” and “the door opens” are triggers, not conditions.
If I select a somfy device , than i can select this as trigger
That should be a bug. Pls share the flow.
Those are convenience cards that the app developer apparently added to their app. It’s not how most apps work.
so i need the
use the Somfy device ?
No, you need to learn how flows work :smiley:
You should look for a trigger (ALS/WHEN) card for your Shelly (“consumption changed” or “power changed” or whatever it might be called) and then use a Logic card to perform the higher/lower check.
