Is Google Nest support still wanted?
Yes I would definitely run these steps if necessary.
I’m not realling looking to make money of of this though. I am a software developer and I was looking forward to create things for homey and share them with the community as I use alot of plugins that other people created as well. Currently I am trying to make the doorbell integration 100% solid (or 99%…as solid as I can) to make sure that I can deliver a product that is up to the Homey standard.
Currently have the following flow working:
It’s a bit hard digging through so many different docs :slight_smile:
It’s the first time creating a Homey app for me (and I’m not really a Typescript programmer, my job is C# and used to be PHP. I do know alot of Javascript though so I can get the gist of Typescript pretty easy) and it’s also the first time dealing with Google’s very annoying API. I will have to combine OAuth with the Pub/sub services to get everything out of the API.
Please check out this post as well: [APP] Google Smart Device Management integration
Can you also retrieve an image if the doorbell is pressed?
Yes, the event that Google supplies contains an Event ID that I can post to another endpoint to retreive an image URL and possibly even the video feed. I should be able to dump that in a Homey tag that you can use in an automation to say, stream the image to your TV or whatever.
That is great! I hope in using the image when the doorbell to be pressed that can be send to homey as a notification. Also to use this image to work with FaceID
i would like to use al that functionality :smiley:
Does the API have anymore action/triggers for the hub?
Yes, please!
What is the hub? Is that like a Google Assistant? Is that the display version of Google Assistant? I don’t think there’s anymore to do then the default chrome-cast app already does.
Check out the API here; Camera  |  Device Access  |  Google Developers
On the left you see device guides and the traits that each device has.
It’s an assistant with chromecast and a display. Which shows additional info on screen when you talk to assistant. You can also watch video like YouTube and Netflix.
What would you like to control that is not already possible? I have alot of Google Nest minis and one Google home, the base unit.
Display information on the screen, like calendar, traffic information, recipes from a flow triggered by homey.
I’m looking for Nest support too, but only for Nest Protect.
Is this helpfull?
Smoke+CO Alarm API | Nest Developers
I don’t think so this is the old nest api that was killed for new users by Google in August 2019
@b03tz
You are impressive. Keep doing that great nest integration, it s thousands of people you will make happy…
Extremely interested! I’d love to let Homey turn on the porch lights when someone rings my doorbell.
Awesome idea!
Yea, I can only use the new API
I dont see that support in the API now :frowning:
