Hue tap dial falling out
After swithing to pro 23 from pro 18 some of my Hue tap dials stopped working and i have to exlcude and include them again?
Why just some of them and not all?
How can prevent this from happening?
Hard to say with this small amount of details.
  • How did you switch? Via backup restore or did you manually setup the new Homey?
  • What do you mean with pro 18? There’s a Pro Early 2019 and an early 2018 (non pro), see below list:
    • Homey Pro (2026)
    • Homey Pro mini
    • Homey Pro (Early 2023)
    • Homey Pro (Early 2019)
    • Homey (Early 2019)
    • Homey (Early 2018)
    • Homey (Early 2016)
  • Which app do you use to connect the Hue devices?
  • Are you using the Hue Hub or not?
  • Are the dials working / available in the Hue app (if applicable)?
  • Is the issue reoccurring or a one time issue?
  • Is exclude and include a (temporary) solution or a question?
Good questions, I think it’s possible to get answers, we just need a bit more details :slight_smile:
I meant the early 2019 and i switched via backup.
Im using the Hue bridge pro
including with Philips Hue athom b.v (yellow logo)
Dials are not configured in Hue app
it seems like its reoccurring but just on some of them?
Ok, so you use the Philips Hue app (with bridge), but you haven’t configured the Dials in the Hue app. Do you mean configured or installed? Usually when using Philips Hue, you add devices in Philips Hue and you can than add those via the Philips Hue app in Homey. Via this way the Philips Hue bridge has his own Zigbee network and usually runs without any issue.
If you’ve added the dials via zigbee to Homey, there might be a Zigbee connectivity issue. Homey creates its own Zigbee network, and the current might differ with the previous (on your Homey Pro early 19). Zigbee networks can interfere with Wifi 2.4 Ghz networks, and that might be the cause that those dials stop working. More on that you’ll find in this tutorial. If you know your way around zigbee and wifi channels this picture tells alot (otherwise read the article)
Can you verify how those Hue Tap dials are added to Homey?
Do you mean you restored a Pro 2023 cloud backup to an Early 2019 model?
I didn’t know that was possible.
Maybe it is, but I can’t select my Pro 2026 cloud backups, only cloud backups from both my Pro 2019s:
