I bought the mss315 power plug and i cent find the exect model on my homey.
I try to connect it with similar plug name in homey ( mss310) but i cant find it or add it.
Do i need to do somthing else?
I connect it to the meross app and not to smarthings or google home if it make any difference.
In case you own a Pro 2023/Mini, you should be able to add it as Matter device, which doesn’t need an app by default.
I have the old round white ball homey
Homey pro i think, and it does not support metter
The product page suggests the plugs are Matter-only, so you won’t be able to make them work with your Homey.
Can u recomend on plugs i can use with my homey?
And maybe use the ones i ordered over lan or somthing like this?
This is a way to start for selecting other compatible plugs:
Like Robert verified, those units are Matter only, they only connect with a Matter controller.
One solution could be throwing Home Assistant into the mix:
I also use Pro 2019’s, and, amongst many other things, I use H.A. for a Matter device, a Nuki lock in my case.
Which can be imported to Homey with the Homey Home Assistant app.
Otherwise you could consider returning the units, if still possible, or put them on the shelf until you purchase a Matter enabled Homey Pro (2023 model and newer).
So i did in other post and with this post of what plug to choose i ordered this… but i didn’t notice thay are metter only
I dont want to add ha to the mix…
If i buy this
https://www.shelly.com/products/shelly-plus-plug-s-white
Will it work with ny homey and enegy monitor?
