How can I display Tasmota data?
I have an MQTT server and MQTT client set up, along with two devices that provide data from our electricity meters. I can see in the client logs that all devices are connecting and sending regular updates.
I can process the data in flows, but I haven’t found a truly practical use for it yet. For example, if I send the meter readings via WhatsApp, it becomes annoying every few seconds. :wink:
Is there a way to easily display the meter readings on a dashboard and perhaps even analyze monthly consumption?
Adding a Tasmota device directly doesn’t work because no device is being detected."
To get a device for these values, you have to create a so-called AVD (Advanced Virtual Device) with the Device Capabilities app.
Please use this link to install the app, because it’s the lastest test version of the app, already published on December 7, 2023. You can believe me that this version is stable.
As the creation of an AVD can be somewhat complicated, I recommend that you first read the relevant app topics and ask questions there if you have any problems:
[APP][Pro] Device Capabilities - Enhance the capabilities of devices
[APP][Pro] Advanced Virtual Device (Device Capabilities App) with Unique Text Status Indicator
If you want to display insights (graphs) in the dashboard, you need to check the option “Create Insights” in the device settings of the AVD.
For an hourly, daily, monthly and annual analysis of the consumption, I recommend the Power by the Hour app.
And this is the corresponding app topic:
I have no clue, what to do. In the Device Capabilities is 0 matching template for Tasmota power meters… I also guess i would need to add a tasmota device in the 1st place to use Device Capabilities, but this still fails.
What exactly do i need to do to add a Tasmota device? The server and client are working well and i can see all of my devices in the logs of the client. But every time i try to add a Tasmota device it does not find any.
Who said, that the DC app has templates?
No, you don’t need a tasmota device in 1st place to use an AVD from the DC app. If you already have a tasmota device, why should you create a virtual device from it? What sense does that make?
I think there are at least 3 or 4 ways:
  • Ask the app developer if he’s willing to add you device
  • As I already mentioned create an AVD with the DC app. The number fields created in the AVD for the different data from your Tasmota device must then be filled with corresponding flows. I had written a tutorial in which this is partly explained: How to integrate Hoymiles Microinverters via OpenDTU and MQTT
  • It may be possible to use the MQTT Hub app to create your device. However, I am not familiar with this app, so I recommend visiting the corresponding app topic → [APP][Pro] MQTT Hub - Community version
  • As I saw in the Tasmota App Topic, you also use Home Assistant. With the Homey Assistant Community App you can import the data to Homey and create a device accordingly. I recommend visiting the corresponding app topic → [APP][Pro] Home Assistant - Community App
    I’m currently doing the same with my Tasmota Hichi IR sensor, by the way. The reason for this is, because it’s not possible to use an AVD for the new energy dashboard at the moment.
I find it weird that I have the MQTT server running on my Homey, but I can’t directly see my Tasmota power meter readers. However, I can add these devices in Home Assistant and then re-import them into Homey through the Home Assistant integration.
Somehow, this feels like shooting myself in the back through the chest into the eye…
In Home Assistant, all I need to do is provide the login credentials for the MQTT server, and I immediately get access to all available parameters.
Somehow, Homey Pro feels much more fiddly and complicated compared to the community-driven software Home Assistant. While Home Assistant provides a more seamless and automated experience, Homey often requires additional manual work, configurations, or workarounds to achieve the same functionality.
The biggest disadvantage of Homey is that if a device is not supported by any app, then it is not possible to use it, at least not without some workarounds.
But HA is much too complicated, at least for me. MQTT is maybe an exception, but only because many MQTT clients have HA MQTT Auto Discovery integrated.
But i still have no clue, how to directly add a Tasmota device! As i just wrote: The MQTT server is up-n-running on my HomeyPro. All devices can be discovered BUT - only from Home assistant! Trying to Add a device directly in Homey gives a “not device found”. I dont get what could be wrong here.
These are all from my Homey pro MQTT server:
As already explained by @DirkG: Home Assistant has a specific MQTT autodiscovery mechanism. Homey doesn’t. You need a specific app if you want the same for Homey, and AFAIK, such an app doesn’t exist.
The Homey Tasmota MQTT App supports just some standard capabilities/devices:
The current version of the application supports on/off capability for single or multiple sockets devices, power monitoring, dim, light_temperature, light_hue, and light_saturation capabilities for single socket devices.
(Source App Store)
If you haven’t imported any Tasmota devices with the Homey Tasmota MQTT app, you can delete this app.
To import devices from HA into Homey, please use the Homey Home Assistant Community App.
If you have any questions about this app, I recommend using the corresponding topic.
I expected, the Tasmota app would be able to discover these energy meters, since these seems to be one of the main use cases for MQTT and it also has this:
But since you can set up whatever structure you want for the device, its impossible to guess what to set up on the device that it matches the expectation of that integration.
Im absolutely not happy, that i always need Home Assistant to get things on Homey Pro running and im not sure if i should stick with it or move completely to home assistant. But thats not the communitys fault :wink:
I had also installed the Tasmota MQTT app a few months ago in the hope that I would be able to use my Hichi IR reader for electricity meters with Homey. But that didn’t work either.
I’m currently also importing the data from HA via the Home Assistant Community app. But only because the Device Capability app doesn’t yet have the new capabilities for the new Homey energy dashboard.
According to the DC app developer, however, he is planning to update the app accordingly in the next few weeks. After that, I will also read the MQTT data with the MQTT Broker and Client apps and then write them into an AVD. Then I will (theoretically) no longer need HA.
Edit
@Michael_Fritzsche, btw, have you actually tried it with the MQTT Hub app as I suggested in the 4th post?
I tryed the MQTT Hub, but dont get it running. I did set up one of my powermeter parameters, but i couldnt find any setting regarding the MQTT Server and its authentication. So how does this app discover and access devices? Is the documentation says, it will discover and broadcast all devices… but this is kind of the opposite i want to achive, i want to read data from existing devices and not populate all other to a new protocol
Maybe the information in the linked post will also help:
