[HOW TO] Setup Tasmota device
How to Set up a TASMOTA device on Homey
First, via Homey APP, install
MQTT Broker
MQTT Client
Tasmota MQTT
Then, go to Homey Developer Tools
Go to App settings
Select MQTT Broker
Enter port 1883
Enter a userid and password, this would be used on several other places later.
Save settings, start brooker.
Close MQTT Broker
Start MQTT Client
First, find the ip adress of your homey, set it as fixed!
In the Client settings, ENTER IP ADRESS OR DNS
Enter the ip of your homey
Then, USERNAME FOR THE BROKER, enter the same as you entered in the broker.
PORT NUMBER should be the same as in the Broker.
Save Settings.
Then, set up your Tasmota device, as in the instructions with the device.
In your router, set the IP as fixed.
When completed, go to the ip address of your Tasmot device.
Test the device, by toggle ON/OFF
Works?
Select Configuration.
Select Configure MQTT
Host, enter the IP adress of your Homey
User / password, same as in the Broker
Save
Now, if all is entered correctly, you can include the new device in Homey😊
Nice,thank you ! But should be moved to Tutorials @moderators please
Hi, how can I add more tasmota devices? What should I fill in the brooker and the client?
Thank you
:arrow_up: :arrow_up: :arrow_up: :arrow_up:
I have already managed to add one device, but I don’t know how to add another one ? Thank you
Same way like the first one, just use other name for Topic.
I’m doing something wrong, but it’s not working. I have a Sonoff Basic R2, and I’ve already added it to my Homey. I’d like to add a Sonoff Mini R4 as well. Should I add another device so that there are two of them, or should I delete the original and keep only the new one? I’ve tried both options, and it’s not working. Will everything else remain the same? Thank you very much
All set…When i go to add device, Tasmota, i will stuck on “Loading” in homey… Anyone knows why?
EDIT: Via mobile app it tells me that no devices have been found, but when i look into broker log, i can see that my tasmota device subscribed…
it may take some time. Just on case, restart everything, Tasmota device, Tasmota app etc
Restarted about 5 times, everything, now it works :smiley:
If you could please keep the conversation in English as much as possible, then more people will be able to participate and help you. If you would rather not or can’t communicate in English then please check out Non-English boards/categories:
Deutsch (German)
After a lot of struggle, I discovered this guide, which worked very well. I was on the brim of abandoning my Nous A1T switches, but now I can use them again with Homey Pro. Thanks for the guide.
Somehow Homey lost contact with my Tasmota devices after 15/2/24. I checked all teh configuration details and they shoud be correct. Also I cannot add new Tasmota devices. When I use MQTT client app to add a new device, non are found.
Show us console logs from Tasmota devices.
