Hello I need to restart the homey every 12 hours after homey 2.0.2 update. The homey process I growing in ram over 300mb I have almost disabled/ uninstalled all apps but the problem still persists.
Any body else have the same problem and have any advice.
Yes, I also had problems with the Homey process consuming all memory. I pulled the plug, waited 30 sec. and reconnected. This fixed the problem for me.
Note: a soft reboot (via Homey app) did NOT work.
Same here since 2-3 days now.
As thereâs been no new apps installed I am wondering if perhaps one App may be corrupt, causing some
Kinda uncontrolled memory stack overflow or so;
Fact is: I hate the message âhomey is offlineâ.
People donât want to know that it uses memory, they want to know why it uses that memory
Homeyâs process taking up hundreds of MBâs points to a memory leak. It could be caused by specific apps, but since we donât have access to Homeyâs core, itâs Athom that needs to address this issue (besides, even though the cause might be third-party apps, memory leaking inside Homeyâs core is a bug in Homeyâs core).
Ah, found the memory overview. I never bothered to actually click at that screen: homey app, menu option âmoreâ at the bottom right, click on the settings gear, pick general, click on the memory graph in the overviewâŚ
I have 44 MB on âotherâ, that does not help a lot either.
