Homey Pro migration is a total failure
I want to do some better energy measurements, so I pre-ordered the Energy dongle, only to find out that I need to replace my 2019 Homey with a 2023 model.
So I bought myself a 2023 model, how hard can it be.
Really heard, it turns out.
The good news: the process of making a backup, shutting down old Homey, boot new Homey and restore backup seemed to work at first.
Next up, none of the apps were loaded. I knew I had to wait, so after just over an hour, while not a single app was reinstalled, I rebooted the new Homey. This time, the majority of the apps were reinstalled. Good.
Sadly, none of the devices worked. This was expected for Zigbee, but sadly, Z-Wave was even worse.
When I click a Zigbee device, I get an error message: “This device was migrated and needs to be repaired”. When I try to repair, it did not work like described. Instead, I had to do a factory reset, and when that happened, I got an error message “device is already connected”. That is actually good news, because instead of adding a new device in the GUI, the existing device in the GUI suddenly started working again. Really good news, because I do not have recreate all the flows for this old device. Good, “only” ±20 devices to manually factory reset, and re-add to the Homey.
No such luck with Z-Wave, though. When I click a Z-Wave device, I get an error message: “Invalid Node ID” for each device. When looking at Homey Developer Tools, only 1 device is listed: the Homey itself. After a few attempts, it seems that here too, I have to do a factory reset for all my ±60 Z-wave devices, and on top of that, recreate each and every flow.
I have done 10 of them by now, and this is insane.
I am not at all happy that I have to shelf another €400 for a new Homey, after having spend money on 2019 Homey and all features so far (Backup, Advanced Flows, Dashboards, Energy), but can accept that. What I am angry about is that the support is so poor. Of course, I send in a ticket, but it say I can only expect a reply in 1-2 weeks.
If only there was an easy way to replace an existing device, as in this request: [FeatureRequest] Replace a device, that would already have saved me a lot of time because I don’t have to replace existing flows. I’ll spends some time getting to understand martijnpoppen’ his script ([HOW-TO][Pro][Cloud] - Tool to FIX (advanced) flows after removing and re-adding devices), but it is ridiculous that this is not supported by default. Each device has a nice “Maintenance” section in the settings. It should have been a piece of cake to implement that here.
Right now, I’m seriously doubting why I’m still investing in this ecosystem. It feels like Athom is prioritizing the production of new shit instead of fixing real issues. (Sorry if I sound pissed off, I am angry now).
Everyone can imagine it’s no fun when things are not going as expected.
Please leave out the negative moods and emotions, this is not your average (a)social media medium, thank you. This is just a user forum.
Please send your griefs and complaints to Athom: homey.app/support
I can give you a free hug, but that also won’t solve your issues :wink:
On topic:
Migrating should be pretty straightforward, except for zigbee devices.
Idk what you exactly mean by zigbee ‘repair’, but the only thing you ought to do is: right-click the device tile @ web app, and select ‘Repair’.
Of course there’s always those devices which won’t cooperate, and need to re-pair by having the device enter pair mode.
This is what worked for some:
  • Shut down the Pro19
  • Factory reset the Pro23
  • update the firmware per USB-Tool
  • restore the Pro19 backup
https://support.homey.app/hc/en-us/articles/9302284997660-Migrating-data-from-Homey-Pro-2016-2019-to-Homey-Pro-Early-2023
That sounds incredibly frustrating…
When you talk about “repairing” a Zigbee device, I wonder if that’s a re-mapping of how the Zigbee end devices connect with the Coordinator (the Homey hub).
Since I’m guessing that you probably added quite a few Zigbee devices since you got the Pro19 Homey Hub.
In any case, I agree with you that this should be much easier and it would also be nice if you could get faster support to help.
I hope you get things resolved soon. Good luck :v:
Replaced my 2019 for a 2023 yesterday and the same issue. Setting up everything from scratch would be a nightmare migration. Can’t believe this has been overlooked by Athom. … And on top of this 2023 does not allow to connect to WIFI, works only with a cable…
The bad news is that in the end I had to manually replace all device, and then replace all flows. I finished the last flow earlier this month. It took me a couple of full days, but spread over just over two months (this was not the most fun job).
Replacing all devices was very tedious. Can’t say otherwise. Replacing the flows was easier, since I used a script to do that (weird that this was not supported by Homey itself!). My scripts can be found at GitHub - macfreek/homey-scripts: Miscellaneous scripts for interacting with a Homey smart home controller, in particular the replace-device-in-flows.js script.
