I’m new to Homey and it works very well for the most part. I have the 2019 Homey Pro and did som flows that does not start unless manually started.
For example I did a flow that shuts off the LED screensaver at 19:00, but it won’t start by itself?
Make sure your Homey’s configuration is set to the correct location for your Homey.
Yes, and it works whenever I start it manually (and all conditons are met). But the automation part does not seem to work as expected?
Is the date and time shown on this page (under dateHuman) correct?
Yes it looks correct! Today it turned off before it should instead. So different behaviour but still incorrect
Sometimes the time is a bit f* up in Homey.
To re-set it:
