Homey flows not starting anymore
Somehow many flows stopped starting. A flow that should start 45 minutes before sunset, a flow when someone arrives home, … they work fine when started by hand but they do not trigger by themselves. Inherent restarted the Homey already and are a bit at a loss what else I can do.
Any suggestions?
Thanks, Wilko
I’ve read somewhere Athom changed the offset to max + or - 30.
To check: try to change the value to 44 f.i., you probably can’t save the flow.
I can recommend to use the Sun Events app instead, for (way more) flexibility.
I could change the number so that didn’t seem to be the issue. In the mean time I have installed Sun Events (impressive options btw.) so let’s see what happens tonight.
The presence thing had to do with the Location permissions somehow being revoked. that is now solved and was independent of the sunset issue.
Bummer. Nothing turned on as planned. I set the flow to start 30 minutes before the sunset but now, 10 minutes before, nothing happened. Anybody any other suggestions?
Strange; I also have flows on sunset with an offset and that is still working fine.
This is 20 minutes before sunset.
Can you show your flows?
You mean also when using the Sun Events app?
If so, you’d have to force Homey to set the timezone correctly (even when it seems OK);
Go to location, move the map to have the pointer in an other timezone than yours, wait a minute, move the map back, or enter Homey’s current address.
Now the timezone should be correct again.
I’m a bit embarrassed to say it is even simpler. I used 45 as offset, but that should have been minus 45 :flushed_face:
It now works.
