Flow date time issues
About a week ago my flows stopped working correctly, the triggers inverted after working for months without issue.
It has been very frustrating trying to fix them, with multiple restarts of my device and re-editing the flows in a hope to fix.
date and time, it’s daytime is now inverted and works at night time in Australia, and using it’s nighttime the same.
So I tried to install Sonnenereignisse thinking that the it’s daytime was still believing it was daytime. so using the Sonnenereignisse golden hour settings it still was not triggering. So ran some flow tests and the test were doing the opposite, so I inverted the logic and then it worked.
I have checked my timezone and it is set correctly, I also checked the device time which is also correct.
Does anyone know if this is an update bug or similar?
When Sun Events app is also off, you most probably have to force update Homey’s clock (even if Homey’s clock now seems correct).
To proceed:
Go to Location
Move the map to get the pin into another time zone
Wait one minute
Move the map back to have the pin @ Homey’s location
Or
Enter Homey’s address
(Settings get auto-saved)
thank you so much, that fixed the issue. It was doing my head in.
Great to hear. You were not the only one with this issue.
It’s really a bug, which is not visible at first, because the local time shows correct.
I’d like to recommend reporting it to homey.app/support
It would be nice if you would mark my post as solution, for future topic readers.
Thx!
