Do you only have access to iPhones or also an Android ?
Hmm that doesn’t make a difference then.
Green is not specified here
so that’s odd as well:
https://support.homey.app/hc/en-us/articles/4405896417426-Understanding-Homey-Bridge-s-LED-Ring
How is your wifi configured? Do you have a separate 2.4GHz SSID for the iot devices?
Try adding the bridge again while 5GHz is temporary turned off, and 2.4GHz mode is set to b/g only (not b/g/n for instance).
The hints below can be used for the bridge as well:
No response on Slack yet… Did you inform support in the meantime? https://support.homey.app/ and scroll down to ‘Customer Support’
I am experiences exact the same problem as Kristian_Juberg. Was this problem ever solved?
I hope everyone also reports issues to Support? https://homey.app/support
