Home problem connection
Hi, my Homey I connected and ring is blinking multicolor light, but I can’t access on web or app. Error is impossible to connect. What is the problem? Is the 4th that I have this problem. Only solution is reset homey but I will lost my data!
That suggests it might be something in your home network that’s causing this. Do you use separate VLAN’s or WiFi segmentation?
I think no, do you have a tutorial to separate that?
If you don’t think you use it, you probably don’t.
Any solution? I’m going crazy…
Power problems? Try to replace the power plug. Seems that some problems are related to a weak power device.
is it a Homey Pro Early 2023? an older Homey Pro?? or a Homey (Cloud) eventually with a bridge ???
and 100’s of other tips to ask for help efficiently
[Tip] Problems with Homey?
Homey pro 2023…
If the problem occurs after some time, then assigning a static IP address to Homey on your router may be the solution.
The problem could be a port forwarding?
