PLA is biodegradable. Best not use that outside.
I don’t have a 3d printer myself (yet ;)). So i have it made by someone else. Really don’t know what he used.
Hi all, Bit of old topic but ive just made one of these using an aqara water leak sensor and a mount ive found on thingiverse. Seems to work fine but im struggling with the flow.
I have it so that when the water alarm is turned on I get an announcement on my Sonos. But for some reason when water is dripping off the sensor it keeps triggering the announcement over and over again.
How do I make a flow where it will only notify me say once within the hour and not over and over again.
Thanks
Create a new variable type Boolean
When the alarm triggers set it to Yes
After an hour set it to No
In your flow add a logic card if variable is “No”
This way the flow will only run once and after that 1st run stops at the logic card
Until the hour has passed
