Hello Homey Pro Community! I was hoping for some ideas on the best way to retrofit a floor lamp. The sad story begins when we purchased a relatively expensive (for me…) lamp. Due to other things going on, I didn’t get around to testing it out. Once I did, I found that the LED lights that it came with are very high temp (glaring bright white) and are not dimmable. Since it was unreturnable by the time I did this testing, I thought that maybe I could retrofit some dimmable LEDs into it: maybe even some RGBW LEDs that could be controlled through Homey Pro.
That might be doable, but I am stuck… 1st problem is that the wiring access is very tight. The wires must run through the support post and in the back of the fixtures. Looks like about a 6 or 7 mm hole in each of the 3 light backs. Then you also need to get out the bottom of the post which might be even smaller. 2nd problem is picking the right configuration LEDs and controller. There are so many choices that I am stuck.
Any ideas from this esteem group? Any direction you can point me? I really would appreciate the help!
I’m guessing you don’t know your way around a soldering iron
I am replacing the old transformer with a new dimmable one (Zigbee)
I would stick new LED strips along the fixture’s perimeter, disconnect the existing wiring, and hook them up to the new connections.
I don’t use dimmable transformers in my own setup, so I can’t advise on a specific model (perhaps other members will chime in). If it were me, I’d buy it from a physical store so I could return the transformer if it’s not the right fit.
Regarding RGB: I can’t see the voltage of the existing transformer. If it’s 12V or 24V: I would glue the strips around the perimeter, install a controller, connect it to the old wires… I will need 3 controllers
Guess you need a LED driver not just a transformer…
and dimmable LEDs,
best buy it in a set or kit, at least compatible ( according to a shop or vendor) that you don’t have to figure out voltage and current etc…
but there is a lot you can check and choose from according to Gemini Google Search
