Today i also had a problem that Homey did not want to connect to Google.
After a restart of homey everything works fine again.
So please try to restart your Homey and check if it works…
Yes same problem, I’ve had a support case open with them for sometime Initially, I wasn’t able to add my homey back in after removing it as there was issues, was getting the “There has been a problem…”
Now, when I try, I get the same as you, and Homey is no longer listed.
I suspect they have been delisted because it is not working….
This might help, it wouldn’t hurt or break anything:
I disabled wifi of my phone, so Homey gets forced to connect to “the cloud” per mobile internet data connection;
Next, I could connect Homey to Google Home right away.
(On wifi I sometimes had to start the connect procedure 20+ times until it finally succeeded).
i have the same problem…. i can see the homey devices in the google home app, but im not able to sync from the homey app so i cannot see my google speakers and such in my homey app.. same error as the people over.. did anyone fix this? restarting the homey did nothing.. i also tried disconnecting from wifi.
You’re supposed to install the Chromecast app, in order to install Chromecast enabled devices.
Only then you will see those.
This is always the main problem, so consider yourself lucky ![]()
