Since last year I have a mower from Gardena, but it is missing a rain sensor. Of course my Gardena Hub is already integrated in Homey. Now I want to create a flow, which stops my mower from starting, when it’s raining.
I already searched the forum, but did not found anything. I also tried a flow with a variable, but with no success. Does anybody have an idea how to make this work?
Stopping from starting seems to be the key. What exactly did you try and what’s your current use of the mower?
I don’t have a mower myself, but when you’ve got some source of truth about when it (is supposedly) raining (In the Netherlands you could use buienalarm if you don’t have a weather station) I think you could
WHEN
its 19:00
AND
today is a monday or thursday
it’s not raining (Buienalarm card, you can insert an alternative APP card with same capabilities in here)
THEN
Start mowing.
Edit: Oh yeah, you will need to return the mower when it’s mowing and it starts raining (in X minutes).
WHEN:
It starts raining in X minutes (Buienalarm card, you can insert an alternative APP card with same capabilities in here)
AND:
Mower is (choose the state that it’s currently mowing)
Thank you for your input, Anoniemand.
Indeed, the App buienalarm is a good tip, because it has the right cards available for flows. And it even works for German cities. I tested other weather Apps and they did not have the right cards available.
I created a flow how you suggested. However, I can not find any logs if it works or not. Not in the Gardena App itself and not in the Homey App… so I have to keep having a look at it at the correct time.
I installed Simple Log and now I have messages in my timeline, when the mower starts and stops.
And I even have a log file to see all the running times in one place. Perfect.
And I also added a push-notification, when the mower was stopped because of rain.
