Fibaro Dimmer 2 that won’t dim the light up or down. Only turns on and off. Same with the physical switch. Switched from Futurehome hub where they dimmed just fine.
Have removed and added them several times without success. When I add them, it seems like they calibrate normally, with the light dimming all the way up and down. But once they are fully added to Homey, the calibration doesn’t work. Only on and off.
Has anyone experienced the same or have a constructive suggestion for a solution?
