HomeyPro_Fibaro Dimmer 2
After importing Fibaro dimmer 2 into Homey Pro 2023… dimming does not work anymore…only 0% and 100%…anyone knows how 2 make dimmimg work ?
Recalibrate?
Yes recalibrated…factory reset several times…when I inclued i HP2023…the calibration is done between 1. and 2. “3” clicks on the Dimmer 2 unit…it works… after finished … and I sen a 30% command…it goes strait 2 100%…I have some Switchbot “meter+” no problem 2 get them in HP2023…but no temeratur i showing up…
Dimming isn’t disabled in the settings of the device?
Can you control it with a physical switch?
Dimming is not disabelt…I connectet a switch to [sx -s1]… switching on/off worked…I tried resetting dimmer2 several times…the only way to get a “dimmed” light is to set down “maximum level” (25%)…that works…but that means 0% or 25%…I have 5 Dimmer2 units they all work the same way (not dimming)…tried to import 1 to HomeyPro2019…Worked fine there
Can you dim it with the switch? If so it would be better to submit a support request here: Support | Homey Fibaro app is maintained by Athom
