Dijker
May 22, 2020, 9:28pm
11
For fixing your countdown counters you just need to use the script found in you op.
Both Better Logic and CountDown have an configuration page with Variables / Timers you need te configure before the App works.
And wetter you made a mistake and deleted all, removed accidentally the App from Homey and lost all…
If you forgot to make a backup, you are screwed…
If you still have your Flows On homey all configuration can be retrieved.
The script is available here 0.5-recreateBL&CD-BackupFromFlows.js
Instructions
Install HomeyScript on your Homey!
Go to https://homeyscript.at…
For restoring a backup you need to reset your Homey to factory default and follow the procedure from the Athom support article. But see my findings in my post.
Athom has released Homey Cloud Backup service in the latest firmware (4.0.0) and a restore option in the mobile App and Web based Homey Setup .
You need a Homey+ subscription to make backups and to be able to restore backups.
As Alpha tester I already tested restoring my production Homey to a second Homey. I want to share my experience and give tips to migrate for example your Homey to a Homey Pro. (or just any type to any other Homey)
This report is based on tests wit a pre-release version …
