Countdown flow does not work after restart Homey
Hi!!!
I want to have the MQTT application restart when homey starts / restarts after 120 seconds.
The flow I am doing so. But it doesn’t work properly. When homey restarts, the countdown cards show “unavailable card” and the timer does not start.
If I do a “test” the flow works perfectly.
Any ideas?
Thank you!!!
https://homey.app/f/bBnUB2
You need to put some delay for the flow, because after Homey restart it take time to load and activate all the apps.
Hi @Igy
Either I’m not doing well, or the “Homey has started” target doesn’t launch any action.
I have tried this flow. And it does not work. After the restart of Homey, it does not trigger the flow.
But, I’m probably doing it wrong.
https://homey.app/f/A4PgC2
Why not simply use:
When “Homey has started”
Then “Restart MQTTT Hub” (with a delay of 120 seconds)
My Spanish isn’t great, but I’m pretty sure your When card isn’t “Homey has started” but “This flow has started”.
Hi @robertklep
Sorry for my English. True, I was referring to this target. It is a system target that says “homey has started”.
https://homey.app/f/Ty4TC2
If that doesn’t work as expected, you should probably post a support request because it sounds like a bug.
Hi @robertklep and @PetervdK
It really works well.
Much easier and easier than I wanted to do it.
Thank you very much for the help!!!
