Compatibility of Devolo Shutter controls and/or recommendation for replacement
I operate seven Devolo (indoor) shutter controls. Given the Devolo app does not support them I activated them via Homey as a generic z-wave switch. It kind of works, but given a switch does not distinguish between up and down or % of being shutting down, it is kind of clumsy and not flawless e.g. in case a shutter is operating in the meantime manually.
Two questions: is there another App that might work for Devolo shutter controls (I heard that Devolo uses a third party product, but forgot the manufacturer)?
If not, what other shutter controls can you recommend? I am thinking of replacing them by Qubino.
First of all you can ask the app developer, in this case Athom itself, if they are willing to include these devices. However, there is no guarantee and no timetable.
Haven’t heard of it yet, but have you tried to integrate the Devolo RS with the Qubino app? Because they look very similar:
(Devolo RS)
(Qubino Flush Shutter)
Even if the Devolo RS are labeled Qubino FS, it’s usually the case that they use their own manufacturer and device ID and therefore don’t work with the Qubino app.
But as we say in Germany: Only the trial makes wise (Nur der Versuch macht klug)… :wink:
Why not? According Qubino homepage the FS is fully compatible (link). You can also check the corresponding forum topic to inform yourself whether there are any problems.
I tried using the Qubino App to pair with the Devolo shutters, was very enthusiastic when the first green tick mark appeared and disillusioned when at the end of the pairing the device was relegated to a “generic z-wave device”, which is what I had. So I will ask Athom whether they can’t tweak the Devolo App (I did some months ago, but got a very generic response) or bite the bullet and replace the Devolo shutter controls by Qubino ones, although as you suggest rightly so, they may be largely identical.
The first green tick only means that the device has been removed (excluded) from the old system. This procedure works with any Z-Wave device, even if it is not compatible with Homey.
If the Devolo RS is really a Qubino FS, then you can also ask Qubino to add the Devolo RS. Maybe it is a chance.
good idea, I contacted Qubino this morning. Let’s see what happens.
Did you get any answer from Qubino if they can support the devolo RS?
I’ve just checked the change log of the Qubino app. The last change is:
Version 4.1.6 — added HC Shutter FM (MT 02761)
I think that is the devolo RS. That would be great. Can anybody confirm that it works?
I did get a response from them:
"The Devolo Shutter has been integrated into Homey and the app is currently undergoing testing. Once approved by Homey, the app will be released. In the meantime, you may download and test the Shutter’s functionality.“
I did the test, but continued to receive the error message of an „unknown Z-wave device“ and responded
“I tested the Qubino app v 4.1.6 via your link and tried to connect my Devolo Shutter both with the Flush Shutter ZMNHCD as well (given the comment in the app that you added the HC Shutter FM in March) the HC Shutter FM MT02761). In both cases Homey seemed to respond initially positively to the pairing but then after toggling the switches as requested I received in the end a message that an „unknown Z-Wave device“ has been installed. The device was then set up as a simple switch.”
Did not get a further response. Continue to use the Devolo shutter devices as „Z-Wave Switches“.
Thank you for the quick response. I am currently looking for an alternative to my devolo HC as this will be shut down on 31.12.2025. Homey seems to be a good alternative. However I would like to make sure that my devolo devices are going to work with homey.
Can you please check the ID of the Devolo Flash Shutter . It does not work. Could it be that the ID is written without the 0 only 2761? Thanks s lot. Regards Robert
