Change in behaviour: every minute/hour/etc, between
I have a flow that starts every hour between 8-14 o’clock.
Since about 5 September the first run is at 9 not 8.
I have tested and found the same behaviour if I start a flow every minute between certain times. It skips the first minute.
Was there a change?
Yes, there was a firmware update (to 7.1.3) around that time, and firmware updates can cause date/time issues. See this thread.
Thanks, I will respond there
