when creating a flow to do something at a certain time i experience some problems.
for example I have some doorsensors and motion sensors that trigger a light. depending on time of day it should set the brightness, how ever it doesn’t work properly. do i have to overlap the times? or is it fine to set a before 07:00 and after 07:00 time in a flow?
when does this reset? in my opionion it should reset after each date but shurely it doesnt.
when setting a date to do something it also doesnt comply. For examle: if the date is xx-xx-xxxx do something. it never does anything. do i have to set a time also? in my mind if the time is 00.00 then the date changes and it should trigger?
