ik verbind eerst alle nieuwe componenten met de ikea app zelf
daarna open ik homey en lees ik in 1 beweging alle nieuwe componenten in homey
Just as a side note, I am able to add the sensor to Apple HomeKit for some reason.
Isn’t that strange?
I understand what you’re saying @bart_ghysel since I’m Dutch too, but please use the English language in this part of the Community , so everybody can understand your reply ![]()
You can use the QR code or de codes
Interesting, although yet to discover if I received a faulty or damaged in transit Homey Pro, but it took two days for me to connect a dozen or so IKEA devices, to the Homey Pro.
However, once obtained a matter capable Apple TV, it took twenty minutes!?
Think Homey has an issue?
This did the trick. update ikea app, then i went to ikea app and restarted it and immediatlky after 2 days of fighting i worked.
yep, that is how I do it: connect Matter devices to Homekit first and then share them to Homey. Added advantage is that you will get OTA updates via Apple Home every now and then.
I have 17 different Ikea Matter devices connected directly to my HP23. They work perfectly when pairing them. Just insert the battery or plug in the lamp and the devices automatically go into pairing mode, and Homey finds them immediately.
However, four Kajplats lamps broke within a period of five days. They were only about 1.5–2 months old. That was very strange, and it certainly makes you wonder about the build quality. But Ikea replaced them right away — excellent customer service.
Hi, i managed to pair 2x IKEA GRILLPLATS Smart Plug and 2x IKEA BILRESA 2 Button Remote directly to my Homey pro (V13.1.5).
Steps:
After the pairing is done most of my zones didn’t show anymore, but this is fixed after re-starting the Homey app.
Hopes this will help some people.
A fair suggestion but the problem is that the Ikea smart home app forces you to first pair an IKEA bridge and the whole point of owning Homey is to not have additional bridges from additional brands.
I had similar issues but managed to install my GRILLPLATS (and other IKEA Matter devices by using an old-ish spare-phone. (described in this thread: Thread network question )
I don’t use IPv6 at all (disabled in router) so I don’t think that matters.
Short version:
I took my old-ish phone, did factory reset, and only installed & configured Homey app.
Keeping phone, Homey and GRILLPLATS plugs really close together during config.
It took a couple of tries but all the sudden it worked just fine and by repeating on all “hard to config” devices I have all my IKEA stuff properly installed !
They mean the Homey IKEA app, not the one for your phone.
At least for me, that’s definitely not the case. I use 9 additional bridges (Tado, Philips Hue, ThirdReality, SwitchBot, Tuya, Xiaomi, 2x HomeWizard Link, Eufy Homebase) and counting. Additional bridges often come with benefits too, like OTA updates for devices, manufacturer-specific features or support for additional protocols which aren’t supported by Homey.
Just thought I would add my findings, I have had more luck using the web portal instead of the phone app to add my Kajplats bulbs to Homey, but some still show unavailable at times..
So who’s actual problem is this? I find it hard to understand how Homey finds the devices and starts to load it then fails at a thread stage, even when the sensor is lierealy placed on top of the Homey Pro.
This is a ridicualous sitaution… Whta re you supposed ot do, purchase 3 times more IKEA devices than you need and then spean days trying to get the amount you needed to pair. Or scrap Homey as this is the weak link.
The tech support for Homey is non existant and really finding it hard to get from the Homey experts a resolution. It should not b upto the community to trouble shoot the Homey Hardware and also the Homey offical apps…
HOMEY STEP UP YOUR GAME
From my experience, restart your phone and your homey and in 95% of cases this will resolve the issue if you can’t connect your device.
I’m just hoping to raise this matter (pun intended) a bit. I’ve got a number of Ikea thread devices. Bulbs, they mostly connect fine. Remotes, nope. I have three Homeys at different locations, 2023 and 2026 versions, no difference. Connecting via IOS or Android doesn’t help either. It connects perfectly to both of them, but when trying to move it over to Homey, it fails, always.
Rebooting Homey and managing to connect within less than a minute after reboot, I’ve been able to get a single remote connected, but it works infrequently. Also, it can’t be updated. The updater goes to 1%, sometimes even 4%, then fails.
Considering there’s more than a handful of people with these problems, it would be reasonable for the staff to make some kind of note about it. What’s wrong, what can be done, workarounds, fixes. Not looking at anyone to blame, I’m looking at anyone to fix it. I’ve spent weeks trying, so I can’t return them back to Ikea either, too late for that.
The Ikea devices are a pain in the ass to update, make sure to be close to your Homey, keep trying and press the pair button from time to time to keep them awake. It might take a few tries but at some point they should update. They have been behaving much better for me with the new firmware.
I appreciate your response. Those are good tips, but I’m afraid it hasn’t helped so far. In fact, I counted over 60 attempts to update. Having the remote on top of Homey never worked, I got to 4% usually when I had about 50 cm distance. I actually tried a number of options from 5 cm to two meters.
Keeping them awake I believe is a challenge, at least according to the error, but how to do that? If you push the reset button again - the one you use to wake it up - it cancels the update immediately.
The classic works: talk to someone about the problem (or, in this case, post to a forum) and a fix will be found. Well, not quite a fix but I wish to share what got me further.
Basically, I rebuilt my wifi environment. I bought a new access point (Zyxel), disabled the home router’s onboard wifi, forced the new access point to 2.4 GHz only, reset Homey Pro to the new network and I was suddenly able to add two Ikea Thread bulbs, and after a few tries, even a Thread remote control (though only by adding via iOS). Updating the bulbs worked, but updating the remote still didn’t work, though it went to 8% before failing so that’s a new record too. Still, “device stopped responding” in mid update. I wish there was a trick for that problem.
Moral of the story is that wifi has a lot to do with the issues, and it would be greatly appreciated if more tips could be provided in that area. Right now I’m not sure what exact detail helped.
