Hello
I have 4 aqara sensors.
2 of them was very easy to include in homey box but 2 other doesn’t want include!
Somebody have the same issue? A solution?
Regards
Hello
Regards
Did you read this ?? Make the most of your zigbee network
Hi
Yes my wifi is on channel 6 and the zigbee on channel 11.
Regards
So it’s in the overlap and possibly disturbing zigbee. So set WiFi as described to another channel
Hello
Done same issue.
Regards
Just hold the connect button for 5 seconds until the led blinks, after that I keep it alive by pressing it shortly every couple of seconds. Just try and try and try again. Eventually it will add the sensor. Works for me. A bit of a hassle, but you only have to do it once. Once it’s connected it works flawlessly.
And while pairing keep the sensor max 10 cm from homey
