Some Aqara devices can be controlled by remotes from other brands (like IKEA), sometimes even if those remotes aren’t in the same network (so could be your neighbours), sometimes if those remotes are specifically routed through the Aqara device.
In specific cases this can be fixed by removing both devices from a particular Zigbee group, but that’s not possible with Homey.
One useful check is whether the plug is still linked to another Zigbee remote or group, even one from a different brand, as that can switch it on without a flow running. If you have a spare remote nearby, try removing its batteries for a night to see whether the random switching stops. Also check the plug’s power-on behaviour setting, so a brief power cut does not leave it on afterwards.
Do the two affected plugs turn on at the same time, or separately? That detail might help narrow things down. Has anyone tried removing the remote batteries and confirmed that the random switching stopped?
