With the Tractive GPS tracker you can locate your dog or cat anytime, anywhere. You just need to turn on the tracker and attach it to your pet’s collar, after which the tracker will start reporting the location, which you can then use in different flows.
Instructions
You need an active Tractive account and subscription to use this app.
Donations
I enjoy creating apps for Homey and try to support them as best as I can. If you enjoy using my apps a donation in return for the time I put into this is much appreciated.
Credits
A big shout out to @Paul_van_Ulft for providing me access to his Tractive account! Thank you!
I also have problem with adding a device to the Tractive app
Everything works fine with adding a device to the point where I get this pop up page message:
“ New units were found
Choose the devices you want to add”
Hello all,
I have 3 trackers, all 3 active. and online.
After login in the Homey app, comes as a message “Rate Limited” and I can only close the app.
Any ideas?
Er is inmiddels een Tractive apparaatje naar mij op weg om te testen. Weet jij of het mogelijk is om de GPS coordinaten in Homey in een variabelen op te slaan als een GPS waarde is gewijzigd?
