[APP] Tedee
Could you elaborate what you mean, or what you want to achieve?
If my daughter put in her pincode I want to set her as home as an example
Unfortunately, Tedee does not support this functionality. Would be cool though!
Will there be support for the Keypad Pro? Kind of affects the choice whether I buy it or not.
Hopefully we will be able to use the keypad for other things as well (starting flows etc) because there still isn’t any good outdoor device for this for Homey Pro. Could boost Tedee sales as well I guess.
No news on the Keypad Pro support?
Nope. You should contact Tedee about this, but I think it has something to do with battery life etc.
When Tedee starts supporting these kind of events, I will implement them in the app.
These kinds of events? I was talking about the new keypad.
Yes. If you want it to trigger a flow, an event must be fired from the keypad to Homey right?
Ah I thought you meant that these events would cause issues with battery life.
But I contacted them, they say I can add the Keypad Pro to Homey (but don’t say how) and say functionality is limited (but they don’t say wat the functionality is)
:confused:
The normal keypad is already supported, so I guess the Pro version works aswell. You can see the supported functionalities on the Homey App Store page (see the first post in this topic).
I worked around this with this flow, which retrieve the “pin Alias” used to unlock a lock with the Tedee cloud API directly after a lock is unlocked:
You’ll have to go through some hoops to get an API Key (see Getting started — Tedee API documentation documentation).
would it be possible to add a function for Keypad? If someone rings the doorbell, so that I can add it to flows? For example, if someone presses the doorbell, I get a notification on the speaker and a sound notification is played.
Thank you and have a nice day.
If this webhook is working, I could add this functionality. I didn’t know they added this webhook. I will try this next week.
Done! It will be available in version 1.8.0 of the app, which is currently in review by Athom. :partying_face:
I did noticed a significant delay from when the button is pressed, to when the event is received by Homey. There is nothing I can do about that unfortunately.
Thank you very much it works correctly
Michal Sihelský a Izzi
Dňa ut 8. 7. 2025, 0:43 Edwin van de Pol via Homey Community Forum <notifications@athom.discoursemail.com> napísal(a):
Is there any way to retrieve the Tedee door contact sensor status like competitor locks do (Nuki or switchbot)? For example for flow automation?
EDIT: Ah, it is available here.
Unfortunately, I cannot test it myself because I do not own a door sensor.
EDIT 2: But I am working on it! :wink:
Done! Door sensor support is added in the new version (v1.9.0) which is in review by Athom.
Please let me know if everything works.
I missed your reply. Nice solution.
My intended use was, put the keypad pro outside and use it unlock the door between my garage and home, which has the tedee pro, and open my electric garagedoor at the same time.
Not sure if this is safe to so. The frient keypad could achieve that but it’s ugly. :sweat_smile:
FYI: if you do not want to buy the bridge, but only want to open/close your lock or read the status, you can also add the lock to Homey via HomeKit! See my post here: Tedee smart lock - #21 by HomeyRob
