ID Lock 150 and flow
Hi!
My ID Lock 150 works great with Homey for locking and unlocking via the Homey app.
But I can´t get it to work in flows. I have the Z-wave module. Anyone with simular problems? Any ideas how to fix this?
Bumping. Used to work fine for me, but a while ago it just stopped to work from flows. Manual lock and unlock works fine from Homey app. Tried reboot, PTP and rewriting flows to start with tags. 2023 Homey on auto update. I might lean towards that issue was introduced when I added 2nd Idlock 150.
Edit: will oc try to remove the new lock when I remember to and are nearby the door for the ‘unclude’ process…
Lonely in here… :zzz:
Removed one lock, the now single one responds from flow again. Sent a message to Idlock some days ago on fb, but surprise surprise - no answer yet.
I just encountered problems using ID Lock 150 in flows myself and found this thread by searching.
When I try to lock/unlock via a flow I just get a senddata_timeout error. I don’t seem to be able to lock/unlock via the app either anymore (it worked when I tested it just after including our locks, we have two).
@tommborge, did you get a reply from ID Lock?
Nope, no reply. In the last of my many attempts to find a solution, I added a virtual button and hooked it to a flow to lock the door, one for each lock. I push these from an advanced flow with a one minute delay between them.
If I remember it all correctly…
Will not buy more products from Idlock, their attention to customer service is simply not good enough. It should be an easy task to pay attention to what happens in forums like these, and give some form of feedback.
OK, so the delay fixed the problem?
I’m afraid my experience is much the same, plus that I’m not happy with either the installation process or the build quality of these locks… :neutral_face:
Yes, that last one worked. And since then I have not spent time to check if anything else would have done the trick, or if it automagically got solved by divine intervention or other app-updates…
fre. 3. jan. 2025 kl. 14:34 skrev Torfinn Brokke via Homey Community Forum <notifications@athom.discoursemail.com>:
Any fix for this yet? Homey does not seem to get an updated status from the lock when it’s unlocked manually - so when the night flow runs, it doesn’t actually lock the door, because homey thinks it’s already locked. Can I force a status-update/ping from the lock the minute before a flow?
