May 4, 2024 • 8:19AM PDT
Backup video link of previous update
For anyone that cannot view the link in the previous update. I’ve created a copy in Google drive. Please see the following link:
On the local API, can we also change the strength used? On the official (cloud) app, during calibration you could switch between the motor strength used.
I think this might have to do with the bug in Homey firmware (" Fixes an issue where capabilities would be outdated after a reboot."), but I am not sure. Will try to investigate as soon as I have time.
So sad they didn’t make it.
But now switching over to local is giving me trouble to connect.
I’m at the pop up screen in home to switch to local. I press reset button twice. It flashes 5 times. Sometimes it does sometimes it doesn’t. But honey stays on the pop up screen.
Rebooted en hard reset slide but with no results
@Astrapowerrr have the same problem… somehow it’s not always working that you can connect slides to Homey with local API enabled. I already emailed Kaj, but unfortunately he can’t help either.
I had some problems in the beginning as well. I think I have had to set it to the local API twice.
I waited for a few minutes after the last time, then unplugged the Slide for a few minutes then plugged it in and waited a few minutes before trying to add it to Homey.
unfortunately, already done this several times. in the beginning homey could not find the curtains at all via local API. After I restarted Homey, they were in the App for adding. But unfortunately, the curtains do not respond when I want to operate them via Homey. Only the cloud connection (via the Slide app) continues to work. According to Kaj, this is correct, because the latest update makes both possible (if the curtains are set on Local API) (until he pulls the plug on the cloud server) For now I don’t know what to do with the Slide curtains… it sucks bigtime.
@Pairis just his support e-mail address what you can find on the Slide website.
(not interested, just trying to help) how old are yours? Mine are from late 2019, and one got replaced in 2022. Both Pro’s by today’s standards. Are they connected to the same WiFi network as Homey? No VLAN’s or other firewall setttings?
What I did:
Both Slides were functioning properly on cloud access.
I deleted Slide 1 from Homey
On Slide 1 I pushed the reset button twice within 0.5 seconds. So switched to local api.
On Homey I clicked “Add device” → Slide. There were two Slides!
I added both.
Slide 1 was working already, but Slide 2 was not.
On Slide 2 I pushed the reset button twice within 0.5 seconds. So switched to local api.
Now also Slide 2 was working in Homey.
Your help is also greatly appreciated! And yes, i think its my Unifi stuff what blocks something… Homey / Slides are on the same network, but still something is blocking de API request i think. I’m going to try using a separate AP to link the Slides…
