[APP] Prometheus.io exporter
sended an PM, Thanks!
Hi
anyone has an idea how I can get variable in to prometheus. I enter a variable and if a certain action happens it heightens the valer and I want to see this.
Variables are introduced in 0.2.6 currently in alpha.
@Kyrcio did you send an invite? i didnt get anything
I think I did, but I just sent another one just in case :slight_smile:
Hmmm, i checked the email adress that i send you, thats correct. There’s nothing in my spam folder. What could it be…?
I am actually not sure an email is sent at all. Assuming that email is the one you use for your Athom account, maybe you already have access?
Jep i can switch now to the alpha without any notification indeed. Installing now
Ok i’ve got the extra cpu stats. What should i be looking for?
HELP homey_cpu CPU time per mode
TYPE homey_cpu gauge
homey_cpu{mode=“user”} 18000000
homey_cpu{mode=“nice”} 3144000
homey_cpu{mode=“sys”} 15116900
homey_cpu{mode=“idle”} 51280300
homey_cpu{mode=“irq”} 0
Try this one to get started
Nice DB!
This is the last 6 hours (04:00 is a scheduled restart)
We have made some progress that i wanted to report back.
i’ve installed the app directly from github (CLI method) and before installing edited this line (in the app.js file) :
setTimeout(this.updateSystemInfo.bind(this), 30000);
To this:
setTimeout(this.updateSystemInfo.bind(this), 300000);
This really impacted the load on my homey, it went to 0.3 on average!
Thanks again @Kyrcio
Hi
Very good job
I have a Raspberry Pi with Prometheus + Grafana and all works fine
Just a question, is it possible to have the weather data ?
I can’t find it in /metrics …
Best regards
Hi @DomLAJO
Im using the darksky wheater app for this, then the metrics show up.
@DomLAJO Homey weather info is in 0.2.6, now in alpha.
Hi @matrover/ @Kyrcio , I imported theDashboard but I don’t seem to have the homey_exporter_XXX metrics available. I don’t see them when I get the /metrics results from Homey, and they are also not available within Grafana.
So the dashboard now looks like this:
Any ideas?
Hi Kay-Arne,
Jep, you’ll need the github version of the app: https://github.com/rickardp/homey-prometheus-exporter/tree/48285237bd4e10c00f397675733c0f2255b5e742
Install via cli: [HOW TO] CLI install method
Hey @matrover, that did the trick! Thanks! Now let’s start scrutinising :wink:
Correct me If i am wrong i have hassio working with grafana and prometheus,that works fine,the dashboard homey expander works but is that the only dashboard I can use with homey
Hi
In homey 3.0 there is now new devices with energy “measures”, but I can not find these in the prometheus exporter.
Is this something to be fixed in prometheus? Or …
