Submit the debug log from the app…
You have zhimi.humidifier.ca6, that’s not supported yet…
Thanks @Sharkys
One question, how come that I can still use the humidifier via Homey? I even use flows with it. Only thing which isn’t showing is the water tank level. You think this will be supported in the future perhaps? ![]()
Great! I’ll monitor and report back via debug log
Thank you very much!
Hi, I work with this App and works great
Thank you! I already got a reply from @Sharkys this version of the app supports my humidifier ![]()
Good evening @Sharkys ,
V.3.4.64 is working for me, it shows my humidifier correctly and now I even get a message through a flow that I have to re-fill the water tank, only thing is the water tank level stays at 50%, no matter how full or empty the tank is:
Should I send you a diagnostic report?
Yes.
Hi, I would like to confirm if the Aqara Z1 Pro is already fully supported on Homey Pro. I want to ensure that all of its features and functions work correctly before I make the purchase.
I look forward to your response. Best regards.
OKay, thank you, but probably you posted in wrong thread.
Based on the overview of supported devices on the Homey app store page of the Aqara app, this device does not seem to be supported (yet).
Also the supported devices overview on the dedicated forum topic of the Aqara app, does not include this device: [APP] Aqara & Xiaomi Smart Home - Simplify your life with a smarter home.
You might want to head over to that dedicated topic and reach out to the developer for info on the planned support for this device.
48abda6a-39dd-4b47-b013-682338fdbd57
Goodevening @Sharkys I tested 3.4.65 with the water level mapping but now it stays at 100% no matter how full/ empty the tank is. I’ve send a diagnostic report (I suppose) Do I still need to share the ID? Can you check if you received it? Thank you!
I’m trying to add my Xiaomi Robot Vacuum X20+ (xiaomi.vacuum.c102gl) to Homey Pro using the Xiaomi Mi Home app.
I entered the IP (confirmed in Mi Home → Network info) and 32-character token. Both Homey and the vacuum are on the same Wi-Fi network.
When I press “Test Connection” I get: “Timeout after 30000ms” ![]()
Is there anything else I should check?
Thanks!
You can submit debug log from the app, but how did you get the token, using Token extractor? Ping to the vacuum robot works? No Wifi Client isolation enabled on your side? If the answers are Yes, Yes, No - pls. submit log
- Yes, I used Xiaomi Cloud Tokens Extractor.
- Yes — I confirmed connectivity from Homey’s SSH sandbox to the vacuum (curl to 192.168.178.186 returns “Connection refused”, not timeout, so the device is reachable). Ping from my Mac also works (7-17ms).
- No client isolation — checked the Ziggo modem admin interface, no AP/Client isolation setting found, doesn’t appear to be enabled on the main network.
Diagnostic report ID: f11c30bc-6139-4b6e-adb1-d98f73da498c
You are not on latest version, please try with https://homey.app/en-cz/app/com.xiaomi-miio/Xiaomi-Mi-Home/test/
